AWD BC Coilover kit
Old 01-05-17, 08:32 PM
rL-gT
rL-gT's Avatar
Smile AWD BC Coilover kit (Installed with Pics)
Been waiting for BC to come out with a coil over kit for the AWD 3IS models. Couldn't wait anymore and decided to take a little project on for myself
Tried doing my own research online and came up short. Did a quick test fit of the 2IS Coils on the rear of my 3IS and found out that they would almost work with some slight modifications. (Rear lower mount bushing needs to be slightly bigger. Can fix with washers)
Mind you that you're relocating the spring from the lower control arm to the shock body.
So anyways. Onto my current project.
Found a set of used 2IS IS250 / 350 BC Coils for cheap.
Found a slightly used 3IS RWD BC Coilover set up for a decent price and went to work
Took apart both front coil overs to find out that the top mount and shock body both have the same dimensions. This was a huge sigh of relief.
Swapped the lower mounts over from the 2IS coils onto the 3IS coils and found out I had plenty of room to slam the vehicle in the front.
I plan to install the coil overs Saturday when I gain access to a hoist and will keep this thread updated.
Hopefully BC North America will read this and get off their asses. The 3IS only comes in AWD up here in Canada and I honestly did not feel like spending $3000 on RSR Coilovers.
Pic 1: Old cheap 2IS Coil overs
Pic 2. New 3IS Coil overs with 2IS AWD Lower mount
Pic 3. 3IS RWD Front Lower mounts on old rusty 2IS Coil overs.
Attached Thumbnails AWD BC Coilover kit-image1-1-.jpg   AWD BC Coilover kit-image2.jpg   AWD BC Coilover kit-image3.jpg
Old 01-05-17, 09:21 PM
gbgary
gbgary's Avatar
their site says $1899.00 http://www.rs-r.com/product/lexus-is...oilovers-2014/
hope your project works out for you.
Old 01-05-17, 10:06 PM
rL-gT
rL-gT's Avatar
Works out to $2500 Canadian + $250 shipping and duties = close to $3000
Old 01-06-17, 11:08 AM
JM Auto Racing
Sponsor
JM Auto Racing's Avatar
BC Racing has an AWD IS coilovers
We sell them all the time
__________________
Email:sales@jmautoracing.com
AIM: jmautoracing@gmail.com
www.jmautosports.com
1-855-998-8726
Old 01-06-17, 11:17 AM
rL-gT
rL-gT's Avatar
Where? Lol.
And you still only have RWD only listed for your 250 / 350 models.
Old 01-06-17, 12:28 PM
gbgary
gbgary's Avatar
ah...gotcha.
Old 01-06-17, 01:50 PM
ToDesi
ToDesi's Avatar
Yeah, where and how much?
Old 01-07-17, 12:36 PM
rL-gT
rL-gT's Avatar
Coils installed and the car feels great.
Have them set at 25. Might play around a bit more with them.
Just need them to settle now.
Kept the car the same height as my super downs. Will go lower in the summer.
Attached Thumbnails AWD BC Coilover kit-img_8069.jpg   AWD BC Coilover kit-img_8071.jpg
Old 01-09-17, 05:55 AM
JM Auto Racing
Sponsor
Where? Lol.
Here is the link
http://jmautosports.com/bc-racing/bc...i-3730757.aspx
__________________
1-855-998-8726
Old 01-09-17, 07:18 AM
JM Auto Racing
Sponsor
Post updated
__________________
1-855-998-8726
Old 01-11-17, 10:54 PM
jlopez3983
jlopez3983's Avatar
will the active dampening still work with these?
Old 01-12-17, 05:59 AM
JM Auto Racing
Sponsor
Like 99% of aftermarket coilovers your AVS system will not work anymore.
__________________
1-855-998-8726
Old 01-14-17, 12:05 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
I see the spring rates are high (on paper) for the BC BR coils:
F: 10 kg/mm
R: 12 kg/mm
@redline.GT or anyone else:
Is the ride firmer than say RSR springs which are softer on paper at around 5kg/mm - 8kg/mm (f/r). Not sure if this is a direct comparison and if the damper adjustments on the BC coils allow for a softer ride despite the stiffer springs. I want the dropped look as the first priority, then good ride comfort (like stock if possible), and finally handling performance. I had RSR Downs on my past IS and was pleased with them but willing to try coils for the possible improved handling/ride comfort.
Old 01-14-17, 02:32 PM
rL-gT
rL-gT's Avatar
F: 10 kg/mm
R: 12 kg/mm
Right now they are not comparable in terms of stiffness / ride comfort just cause I have mine set to a semi stiff set up. I'm loving them so far tho and I've got no regrets.
Just wish I could go lower right now.
I Had RSR Super Downs and they drove nice. I would still recommend them to anyone looking to grab them
byronm1234
10-07-17 02:17 PM
robert2423
02-19-17 08:31 PM
asapcolin
Suspension and Brakes
12
12-06-15 04:20 PM
FiLtHyGS
12-01-15 05:42 PM
PaPaHoFF
06-20-10 03:00 PM
Quick Reply: AWD BC Coilover kit
