Exhaust mod ideas?
I am also considering doing the muffler delete. Do you guys know if local muffler shop can unbolt the mufflers and replace with bolted on pipe so that the mufflers can be put back on if needed?
OBX FULL CAT BACK $599
TSUDO FULL CAT BACK $600
J2 FULL CAT BACK $494
Follow my Instagram page for more details on 3IS performance parts
@Lexus_performance
@Lexus_performance
Unfortunately stock mufflers aren't "bolt on's", they're welded so unbolting them isn't an option. They will simply cut the pipe behind the muffler inlet and weld a new pipe in its place. The back tips will be welded onto that pipe. If you needed to return the vehicle to the dealership you would simply reverse that process before delivering the vehicle back…
It could be the 4- cylinder turbo but my V6 sounds much different. I didn't touch the resonator but did delete the mufflers. Mine has a much deeper/ throatier sound.
