Help! Should i get 20 inch rims?
Old 12-03-16, 09:22 PM
jackdahou
jackdahou's Avatar
Default Help! Should i get 20 inch rims?
Will Vossen cvt 20x10, 45 offset with 245/35 work? ( squared setup ) Do you guys think i will rub with this setup? I am currently on stock suspensions with my 2014 is 250.
Im currently running 19x10 35 offset, 255/35 and i am rubbing like crazy! I need to switch to a new setup asap! All information and suggestions will be appreciated!!
Old 12-03-16, 09:48 PM
robert2423
robert2423's Avatar
i am currently runnin 20x8.5 et25 and 20x10 et43 with a 235/35/20 255/35/20
I only rub over big bumps on the freeway and i mean huge. full loaded car i will a little aswell. but its no deal breaker. I think you will be fine with that set up.
I love 20s everyone complains they are too big but each their own. Running a michelin PSS as well. Fatter tire.
Attached Thumbnails Help! Should i get 20 inch rims?-20160715_202533.jpg   Help! Should i get 20 inch rims?-untitled.png   Help! Should i get 20 inch rims?-20160901_195126.jpg
Old 12-03-16, 10:51 PM
Keithwuuuu
Keithwuuuu's Avatar
Have u considered rolling ur fenders and are u lowered?
Old 12-03-16, 11:30 PM
robert2423
robert2423's Avatar
I don't get how hes rubbing either. He said hes not lowered.
maybe the stock springs are just too bouncy? thats what i noticed at least. maybe something stiffer it wouldn't rub.
Old 12-03-16, 11:41 PM
Keithwuuuu
Keithwuuuu's Avatar
I'm guessing it's too wide
Old 12-04-16, 09:36 AM
zhifan1
zhifan1's Avatar
I am also considering getting Vossen rims, most probably getting the VPS-303 model. However, i cant seem to be able to find weight of the 19" wheels. It's webpage is barren of such info as well. Anyone knows? Thanks.
http://forged.vossenwheels.com/wheel/vps-303/
Old 12-04-16, 10:03 AM
Keithwuuuu
Keithwuuuu's Avatar
This is for reference since these are the Vossen cv5 and most Vossen wheels about the same. It says 53.4 lbs. just in case u can't see the pic clearly
Old 12-04-16, 10:54 AM
dnasians
dnasians's Avatar
19x10+35 will run like crazy without any camber mods. if you want to fix your issue without getting new wheels, get the spc rear camber arms and add a little camber to get your wheels to clear.
Old 12-04-16, 11:05 AM
Keithwuuuu
Keithwuuuu's Avatar
I have the rear spc camber arms, lowered on bcracing coilovers, didn't roll my fenders, and have no issues with rubbing cuz there's about a one finger gap. Also I have stock fsport wheels right now. Sits nice and flush. Camber is very close to stock as well. Definitely rolling my fenders when my new wheels come in tho
Old 12-04-16, 02:31 PM
zhifan1
zhifan1's Avatar
Thumbs up
Much appreciated, mate..
Old 12-04-16, 07:05 PM
robert2423
robert2423's Avatar
maybe contact mike at vossen then? idk vossen are overrated i had some. Team AG now.
Lakersfan
12-01-16 10:03 AM
msgs350
03-26-12 04:12 PM
ECUgs430
06-21-09 08:09 PM
platinumac
Wheels, Tires & Brakes Forum
04-22-08 03:28 PM
Bigbea
04-05-07 04:09 PM
Quick Reply: Help! Should i get 20 inch rims?
