Spark plug replacement - 2014 IS 350
All the threads on spark plug replacement for the IS 350's seem to be for earlier generations, and I'm not seeing any discussion of 2014+. Am I missing it or am I really the first '14 owner to reach 60,000?
Can anyone confirm there's no difference from the earlier generation? Planning on doing it myself and just want to be prepared. Thanks.
The issue is whether the intake manifold has to be removed to access the driver side plugs. Several folks have said no, but those were earlier models. It appears to block access to the rear most plug, as there's just a couple of inches of clearance. If it is just tough but possible I would rather try than pay for it. Any input appreciated.
Per the TIS
1. REMOVE V-BANK COVER SUB-ASSEMBLY
2. DISCONNECT NO. 2 VENTILATION HOSE
3. REMOVE AIR CLEANER CAP WITH AIR CLEANER HOSE
4. REMOVE IGNITION COIL ASSEMBLY
(a) Remove the 2 nuts and disconnect the wire harness from the cylinder head cover sub-assembly.
(b) Disconnect the wire harness clamp from the intake air surge tank assembly.
(c) Remove the 2 bolts and disconnect the 2 brackets from the cylinder head cover sub-assembly LH.
(d) Disconnect the 6 ignition coil assembly connectors.
(e) Remove the 6 bolts and 6 ignition coil assemblies from the cylinder head cover sub-assembly.
NOTICE:
If an ignition coil assembly has been struck or dropped, replace it.
HINT:
Arrange the removed parts in the correct order.
5. REMOVE SPARK PLUG
(a) Remove the 6 spark plugs from the cylinder head assembly.
NOTICE:
If a spark plug has been struck or dropped, replace it.
HINT:
INSTALLATION PROCEDURE
1. INSTALL SPARK PLUG
HINT:
Perform "Inspection After Repair" after replacing a spark plug.
(a) Install the 6 spark plugs to the cylinder head sub-assembly.
Torque:
18 N·m {184 kgf·cm, 13 ft·lbf}
NOTICE:
HINT:
Install the same parts to their original positions.
2. INSTALL IGNITION COIL ASSEMBLY
HINT:
Perform "Inspection After Repair" after replacing an ignition coil assembly.
(a) Install the 6 ignition coil assemblies to the cylinder head cover sub-assembly with the 6 bolts.
Torque:
10 N·m {102 kgf·cm, 7 ft·lbf}
NOTICE:
HINT:
(b) Connect the 6 ignition coil assembly connectors.
(c) Connect the 2 brackets to the cylinder head cover sub-assembly LH with the 2 bolts.
Torque:
Bolt A :
21 N·m {214 kgf·cm, 15 ft·lbf}
Bolt B :
(d) Connect the wire harness clamp to the intake air surge tank assembly.
(e) Connect the wire harness to the cylinder head cover sub-assembly with the 2 nuts.
Torque:
3. INSTALL AIR CLEANER CAP WITH AIR CLEANER HOSE
4. CONNECT NO. 2 VENTILATION HOSE
5. INSTALL V-BANK COVER SUB-ASSEMBLY
6. PERFORM INITIALIZATION
(a) Perform "Inspection After Repair" after replacing an ignition coil assembly and spark plug.
I did change mine twice !! First time 60k second time 120K .. this the picture of the last time I change them !! I know it's damaged but don't forget my car is full bolts-on + Tune
OEM Denso spark plugs : $160 for 6pc
Labor : only $15 LOL
Attachment 400731
Attachment 400732
Attachment 400731
Attachment 400732
REMOVAL PROCEDURE
NOTICE:
HINT:
NOTICE:
HINT:
HINT:
Torque:
NOTICE:
HINT:
HINT:
Torque:
NOTICE:
HINT:
Torque:
Bolt A :
Bolt B :
Torque:
NOTICE:
HINT:
NOTICE:
HINT:
HINT:
Torque:
NOTICE:
HINT:
HINT:
Torque:
NOTICE:
HINT:
Torque:
Bolt A :
Bolt B :
Torque:
it would appear that this was an excerpt from the service manual. Sans some pictures it tells the method of what you need to do. Good luck!
Originally Posted by Monoshock
ok, but what about the intake manifold?
