Front Parking/Marker light
Hello all,
Is it my car or all IS F Sport the front parking/marker light where the dual filaments bulb turn signal isn't lit up. The current bulb is dual filaments and there are 3 wires going to the socket but only the turn signal is working on that bulb. The marker/parking function isn't work. There have to be a setting somewhere. I don't think Toyota/Lexus spend money on a 'none functional' wire. Perhaps this marker function is working on None F-Sport model but disable on F-sport model like the Fog light (wires/plugs are there but need additional components to work).
Does any one know how to turn that on function on is it setting somewhere? I do have Carista to change the setting if it's in there.
I look around the fuse boxes and no front parking/marker written any where.
I'm looking for the parking/marker hot wires to wire the fog light and I want the fog light to come on with parking mode and head light mode. I haven't check all wires behind the fog light to look for this wire/signal. The obvious one is the turn signal bulb but that is not working.
Thanks
Thanks
Hello all,
Thanks
Thanks
http://www.ebay.com/itm/No-Hyper-Fla...ZW3V15&vxp=mtr
Do you have the head light with separate high beam and low beam LED? If you do, I did a test on mine last night.. the signal bulbs do not actually light up as markers. They only function as signals. you may want to tap into the actual side marker light.
I believe the extra wire "may" be for other head light options for other areas... like head lights with bi-xenon (just my guess)
My is the F-sport with low and high LED head lights.
I guess I have to look for that signal at the DRL low intensity (night mode) or the actual marker wire on the head light. Suck that there isn't much room to poking around behind the 'fog light' after pulling wheel liner out.
Or I'm just checking the wiper stack to trigger the fog light wires to turn on. If that doesn't work, engine bay fuse boxes would be the last option.
Thanks
Thanks
KrazeMatik
SC- 1st Gen (1992-2000)
11-27-05 12:47 PM
