Wheel Spacers
Old 08-18-16, 09:53 AM
jkwiseeyes
jkwiseeyes's Avatar
I am currently on RSR downs with 15 mm Ichiba Spacers all around on my IS250 Fsport AWD. I got the fsport rims that came with the car so they are staggered. I'm starting to consider put 20mm spacers on the front, but I don't want to hassle to have to shave down anything... can others mention there experience with 20mm spacers on the front?
thanks, much appreciated!
Old 08-18-16, 10:19 AM
ToDesi
ToDesi's Avatar
So if I get the B2design 15mm spacers I need to shave the studs?
Old 08-18-16, 10:35 AM
Cthan3o3
Cthan3o3's Avatar
I'm assuming you didn't have to shave your stock studs with the 15mm? I was always under the assumption anything larger than 15mm, there was no need shave anything
Old 08-18-16, 01:30 PM
dnasians
dnasians's Avatar
when i measured the stud clearance using a sliding caliper, the minimum spacer you'd need to not shave the studs is 18mm. brands do not make a difference. if you're getting 15mm spacers, you need to cut some of the stud off.
i was running 20mm all around on my car before i got volks, no rubbing issues.
Old 08-18-16, 03:15 PM
Cthan3o3
Cthan3o3's Avatar
I think it's the awd ppl who are having rubbing issues with 20mm
neilvosko
Suspension and Brakes
365
11-13-23 12:24 PM
fdelement
06-27-20 10:12 AM
SteveMason
CT 200h Model (2011-2017)
26
05-06-16 06:32 AM
RTIS250
33
12-07-15 10:00 PM
JDKane527
03-24-09 07:23 PM
Quick Reply: Wheel Spacers
