Check ABS, VGRS, TC warnings after spring install?
Right after I finished changing out one of my springs (slowly working on adding Half Downs in my garage), I am getting Check ABS, VGRS, TC warning lights. Is this because I disconnected the speed sensor wire during the install? I think I noticed it during the install when I had to start the car to turn the steering wheel to get more leverage.
I haven't driven my car yet except to adjust positioning in the garage. Does it need a lengthy drive to recalibrate/reset? I did disconnect the battery to try and reset it, but that didn't fix it. Any help would be appreciated!
Pull out, clean and check all of the sensors going to the wheels. I used 90% isopropel alcohol. Put them all back in. Double check the wires and make sure they aren't damaged. Ask auto zone or any independent mechanic to pull and clear the code for you.
DoWerk
03-10-17 07:28 PM
