Talked to lexus fts/engineer guy about is200t f sport exu
Old 07-17-16, 06:51 PM
leo877
leo877's Avatar
Originally Posted by Megaman
Im not sure where youre getting $1500 for a tune, but any other company charges ~$599-$799 at most.
A tune + turbo back exhaust + intake would put the IS200t in the same neighborhood as the IS350 in terms of performance. We just dont know the costs yet as products are being developed.
Performance wise, I highly doubt ECU tune, cat back exhaust and intake can make 200t as quick as 350. A 350 engine is rated at 306 hp and 200t produces 241 hp according to Lexus. That's 65 hp difference between them. I would say full cat back exhaust and intake can add 20 extra whp for 200t but probably do not expect a lot from 200t ECU tune. It is just like full bolt on 350 cant walk ISF, sample as that.
Old 07-17-16, 09:34 PM
xsdeus
xsdeus's Avatar
Resetting some expectations..
Performance-wise, the 350 is probably a better deal, but some may prefer the engine dynamics of a turbocharged vehicle.
Also, there is that added fun of making a car uniquely yours via modding.
I don't argue that a 200t can equal a 350; they're different cars with different strengths. But that shouldn't automatically make the 200t a lost cause.
Old 07-17-16, 10:09 PM
Machine13
Machine13's Avatar
There is no replacement for displacement.
Old 07-17-16, 10:11 PM
Megaman
Megaman's Avatar
Originally Posted by EZZ
Sorry. I meant an extra chip. Maybe that was a little high. Perhaps $300 like you can get with a VW. The 200t is laggy though. You'd may need the whole shebang (intake, exhaust, tune, chip) to get to 350 levels. Is that worth it when you can just get a 350 with the awesome throttle response and AVS for about the same price?
Understandable. I am not sure if a reflash would adjust the RPM of the spooling, but who knows.
An ECU reflash + turbo back (downpipe + high flow cat + cat back) + intake should put this car in the IS350 ball park. I am a '15 IS350 owner, and based on my previous factory turbo vehicles and mods, I believe an IS200t with full turbo bolt ons would be able to keep up with a stock IS350. The gap between the IS200t and 350 is only ~65hp, the difference between an IS350 and an ISF is ~114. Also, the ISF has an LSD to put the power down to the ground.
I believe an IS200t with full mods will keep up with a stock IS350.
We will see soon enough.
The IS350 F Sport is more than just an engine upgrade, you also get the ML sound system, sport suspension and steering. Even if the IS200t could keep up with the 350 after mods, I still would buy a 350 every single time.
Old 07-17-16, 11:55 PM
xsdeus
xsdeus's Avatar
I don't believe the IS350 F-Sport comes standard with the Mark Levinson sound system. The only non-engine feature it has over the 200t is the AVS.
Old 07-18-16, 10:17 AM
Megaman
Megaman's Avatar
The ones built and shipped to CA all had ML, I cant speak for other parts of the country.
Old 07-18-16, 12:44 PM
Cake
Cake's Avatar
Don't forget the 200t is about 80lbs lighter with the smaller engine.
Old 07-18-16, 12:48 PM
Vivid101
Vivid101's Avatar
Still 60 less hp. 80lhs less wouldn't make any noticeable difference.
Old 07-18-16, 01:04 PM
redspencer
OG Member
Forum Moderator
redspencer's Avatar
Where are you deriving the 80lbs figure from? Lexus specifications have the IS350 official curb weight at 3,593 lbs while the IS200t official curb weight is 3,583 lbs (a 10 pound difference between the two models).
Old 07-18-16, 01:47 PM
Cake
Cake's Avatar
My mistake. The difference is not about 80lbs. More like 154lbs. If you look at the weight of 200t and 350 f sport rwd on the offical lexus site. The 200t is 3583lbs and 350 is 3737lbs.
Old 07-18-16, 01:53 PM
Vivid101
Vivid101's Avatar
The 200t would have to be 2500 lbs in order for me to buy it over a 3600 lb 350. even 150 lbs will not be noticeable.
EZZ
EZZ's Avatar
Website is wrong. If you look at the AWD info, you get the same curb weight. I have an official product sheet attached for your convenience.
Talked to lexus fts/engineer guy about is200t f sport exu-photo92.jpg
They are about 10 lbs apart. This is well know here.
Old 07-18-16, 01:54 PM
JDR76
JDR76's Avatar
Received 1,625 Likes on 1,035 Posts
The 350 AWD is 3,737 lbs. The 350 RWD is 3,593 lbs.
Lexus.com has an error, listing both the RWD and AWD 350 as the same weight.
Here are all of the weights:
http://pressroom.lexus.com/releases/...duct+specs.htm
Old 07-18-16, 03:00 PM
Megaman
Megaman's Avatar
My 350 certainly feels a lot heavier than 3600 lbs.
Old 07-18-16, 03:10 PM
JDR76
JDR76's Avatar
They're just very solid feeling cars. Heck, a RWD GS350 is only 3726 lbs.
Quick Reply: Talked to lexus fts/engineer guy about is200t f sport exu
