Need advice taking my car for its 20k Service
#31
#32
#33
Yes the AWD f sports are staggered setup as well. I have a pretty honest service tech at my lexus dealership and he even said that I can do the 30k service myself by buying parts online and doing the visual checks myself. He told me this when I denied to get the 30k service check and just got the usual oil change. Lol
#34
So the tires can't be rotated. So, the basic maintenance is -
Change engine oil and filter
Replace cabin air filter
Re-torque drive shaft flange bolts
Look at everything else - which a Toyota dealer (or for that matter, any independent mechanic) can do for you, too
Ask around and you can save yourself $200.
#35
#36
Contacted my local dealership for a quote for my 20k mile service. I was quoted $307. Here are the services included.
Factory Recommended Services
Replace engine oil and filter
Road test vehicle
Rotate tires
Replace air conditioner filter (if equipped)
Inspect ball joints and dust covers
Inspect brake linings/drums and brake pads/discs
Inspect drive shaft/propeller shaft dust boots
Inspect Steering linkage and boots
Measure brake pad thickness and rotor run out
Inspect engine air cleaner element
Inspect chassis body nuts & bolts
Check installation of driver floor mat
$ 302.72
Road test vehicle
Rotate tires
$ 302.72
#38
Like everyone here said, save yourself some money and buy the oil filter online. I purchased a pack of 10 oil filters for dirt cheap on ebay, the oil filter part number is 04152-y22A5 and i believe its a genuine toyota part number, my car is a 2014 350 f sport awd. I would call toyota and confirm the part number. When i initially called lexus to ask them what the oil filter part numbers were they refused to tell me which is why i never bring my car to lexus for service because they lack in the customer service department. In regards to the cabin filters and engine air filters i purchased them on ebay for around 12$ for each and it was easy to install, youtube it and it will take you no more than 5 minutes to replace it. And do your own oil change if you can
