Will I Rub?
Will I Rub?
Will i rub by running a 245/35r20 and 265/35r20 in the back? I know my fronts wont rub because im already running that size. But i Rub when i turn really sharp. What if i wanted to drop it eventually using half down or coil overs would i need different tire size?
You're missing some major info to determine if it will fit or not. What offset are the rims? Just plug in the specs here once you know and you will have your answer:
http://www.willtheyfit.com/
