Changing stock bridgestone 18" for the 2nd time in 18k miles?!?!?!
Old 05-03-16, 08:11 PM
jackdahou
jackdahou's Avatar
Default Changing stock bridgestone 18" for the 2nd time in 18k miles?!?!?!
This is going to be the second time im changing tires on this car. I have an awd is 250 2014.
I have the 18" sports wheel. I've changed the front two tires at 8k miles; they were completely bald!!
Well, i was taking really harsh corners and pushing the car alot.
Here i am at 18k miles, and my front two tires are almost completely bald again! Inside and outside.
My sidewalls are cracking on my rear, so ill be replacing all four wheels.
I have not been pushing this car in the last 10k. I've been casually, daily driving this car in new york city roads.
Is this normal? I've gotten an 3 alignments already! After the new wheels are on, and just for safety reasons.
Yeah.. New york city has some horrible roads, I've heard falling into potholes can screw up your alignment
The stock tires are bridgestones! I am at stock height, non f sport height! Which i believe is a little lower than f sport.
Old 05-03-16, 08:23 PM
tea
tea's Avatar
stock tires have horrible tread life. did you get the same tires at 8,000?
Old 05-03-16, 08:26 PM
evident
evident's Avatar
Pro tip, don't purchase stock tires as replacement. They are bad
jackdahou
jackdahou's Avatar
Yes! I got the same stock tires from my lexus dealership. Sadly they dont have tire warranty.
Old 05-03-16, 08:27 PM
CobraGSF
CobraGSF's Avatar
wow thats terrible. yeah these stock tires stink. i am also in ny with a 350 fsport nearing 19k and will be changing out my tires for the first time. only because of bad camber wear that these tires for some reason are subject to. have seen other 3IS owners complain about it. my alignment is not off either. anyway steer clear of the OEM bridgestones. they have a terrible wear rate as the previous poster said
Old 05-03-16, 08:42 PM
tea
tea's Avatar
and you got had by the stealership on top of that too. get some Michelin Pilot Super Sports if you want performance. i like Continental DWS if you want some tires that are comfortable and last a little longer as well
Old 05-03-16, 09:15 PM
atomic250
atomic250's Avatar
Based on the reviews on Tire Rack the stock Bridgestone Potenza RE92 has horrible reviews and short thread life compared to other Bridgestone tires. I'm currently running Bridgestone Potenza RE760 Sport and it's a lot better than the stock tires. If you have the cash then just go for Michelin Pilot Super Sport.
Old 05-03-16, 10:30 PM
Fsportme
Fsportme's Avatar
It helps if you learn how to read tire specs.
Tire Rack has some good info on how to read them. Anyway treadwear rating on the oem Brigdestones is something like 140. The lower number usually means shorter tire wear life and the higher the rating the longer tire life. The positive trade off with lower tire rating is usually excellent grip. All season tires usually have a higher tire wear rating above 280+ up to 500 but don't grip as well as summer tires.
Old 05-03-16, 10:40 PM
TrueDat96
TrueDat96's Avatar
Good thing my car somehow came with Bridgestone Potenza RE760 Sport
Old 05-04-16, 12:33 AM
lexusplz
lexusplz's Avatar
The stock 3IS F-sport comes with Bridgestone Pontenza RE050A (140 tread wear) series. Of course, they won't last long. I have the non-sport 3IS with the Dunlop SP Sport MAXX 050 summer tire ones and those are 280 tread wear. I heard great things about the Michellin Pilot Sport (~320-340 tread wear) or even the Bridgestone Pontenza RE760 (400 tread wear)
Old 05-04-16, 02:35 PM
OvOxNO
OvOxNO's Avatar
Also replacing my rear stock tires at 17k (tires delivered today). Im glad im not the only one having the same issue, I have been racking my brain as to why there may be such premature wear.
Old 05-04-16, 02:53 PM
JDR76
JDR76's Avatar
Received 1,603 Likes on 1,021 Posts
Seems like it varies quite a bit. When I traded in my IS at 16k miles, there was still enough tread left to CPO it without needing to buy new tires.
Old 05-04-16, 09:01 PM
da mayor
da mayor's Avatar
also if you live in NY like myself the real bad road conditions cause that, especially if you drive in flushing when they have not fixed the roads and you don't check tire pressure much.
Old 05-05-16, 10:39 AM
tC2IS350
tC2IS350's Avatar
Agree. I have 26k miles on my OEM all seasons and I won't need to get new tires until later this year. They have lasted me through two PA winters with zero issues. I drive mostly all smooth highway though so I'm sure that's the reason they have lasted so well for me.
Old 05-05-16, 04:14 PM
BostonIS
BostonIS's Avatar
Recently changed to michelin pilot sport a/s 3+ and they're amazing so far. The handling of the car feels great compared to the oem tires. Although I bought my car used at 19k miles and i assume the previous owner used the same oem tires they lasted until 30k. But thise bridgestone turanza's were terrible tires.
Quick Reply: Changing stock bridgestone 18" for the 2nd time in 18k miles?!?!?!
