LED turn signal bulbs
#31
Hi Guys,
I was able to get my bulbs today. They are the second set I've tried, the first being some other eBay ones which required resistors and tapping wires which I didn't like. Although the iJDMTOY / MotoringMax ones require the decoder box, they didn't require me to tap wires / add resistors. They were also super easy to install.
I did a quick little overview on YouTube. I also include a video comparison at full speed and half-speed. The video can be found here.
#33
Hi Guys,
2014+ Lexus IS 250/350 - LED Front Turn Signals - YouTube
#34
I ordered and installed these to. Front ones were cake. Rear ones were hard. First thought u went through the trunk. Big mistake i lost the stud screw for my rear cargo net. You have to pull out tail light. You take 2 screws off the you stand on side and like hit tail away from you. Then it pops off and you can swap bulbs. Really hard if your not used to doing stuff like that. For example me haha. End result freakin awesome!!!
#36
(2) Any vehicle may be equipped and, when required under s. 316.222(2), shall be equipped with electric turn signals which shall indicate an intention to turn by flashing lights showing to the front and rear of a vehicle or on a combination of vehicles on the side of the vehicle or combination toward which the turn is to be made. The lamps showing to the front shall be mounted on the same level and as widely spaced laterally as practicable and, when signaling, shall emit white or amber light.
KennyZ
02-20-18 08:27 AM
