Rocks/cinders in brakepads???
So, this is the second time I have had to take the Lex in to the shop and have them take the wheels off and clear the cinders off of the brakepads. It is so loud when it happens, and I have no idea how to prevent it. I live in Oregon where they use cinders for traction on the ice and snow. Anyone having this happen?
How do I prevent this???
Seriously???
I was hoping someone would chime in and say they had the same thing happen...
should I go vented calipers?
different brake assembly all together?
Schwabs said I really cant do anything to prevent it...
I call BS
I call BS
For those of us who are in the lower states who’ve never heard of using cinders for traction, like myself, I had to search a bit and discovered that I think jeeper is referring to ashes from a coal-fired power plant being used as one material in a multi-material traction mixture applied to roads in icy environments that happens to be approved for use in certain municipalities up north.
Here’s a couple of google finds on this road traction mixture:
http://midwestenergynews.com/2014/03...e-not-so-sure/
http://www.mexicomissouri.net/376/Ci...w-Ice-Traction
The first article makes statements that the ashes can contain trace heavy metals in low quantities.
So, I have a question for you... are you saying that you suspect this road mixture is gumming up at your brake pads?
If this is a newer technology and people are starting to see mechanical problems on their cars from it, I imagine you may be on to something fairly new here. I can’t imagine how you could prevent this except possibly by banding together with others and campaigning your local government to dis-approve this type of road mixture from use.
I don’t currently see how slotted or vented rotors can help you in this situation. Seems like they’ll just get gummed up even worse.
Perhaps Schwabs was right, you really can’t do anything to prevent it.
I was simply asking if anyone had any suggestions on here to prevent the problem. Thanks guys
This is totally bumming me out. It just happened again and is even worse this time. It is so loud that everyone looks when I drive by.
There has got to be something I can do.
It looks and sounds like the cinders are actually getting between that metal plate thing that goes around the rotors. Does anyone know if I can just have that removed or trimmed down?
Getting cinders or rocks stuck in the brake pads is different from getting them stuck in the dust cover on the back side of the rotor. The dust cover can be adjusted (bent) to minimize the open space where they enter or increase the clearance to allow them to fall out. I would think the dealer would know to check the proper spacing of the brake dust cover.
