New brake pads
New brake pads
It's about time to replace my front brake pads. Any suggestions on some good brands for IS250. Looking for some for a decent price and link where to purchase them online
Just picked up and installed a set of akebono proact on my 350F. Bought the car end of December and I couldn't take the dust and having to clean the wheels every other day with the stock pads anymore. Replaced the pads front and back for $82 from rockauto. Rear pad replacement is a little overkill for dust but it was only another $40 for them. The wheels are staying easily clean enough to just wash them every week or so with the rest of the car. The performance is very comparable to the factory ones and they are very quiet.
They're a breeze to replace. Took longer unbolting/remounting all the wheels than changing the pads. I know the Akebonos don't need to be broken in from what the manual says. They're ready from the start but I gave them a few 60 to 5 mph stops just to make me feel better. They squeak for the first one or two stops but then they're silent. There is also no need to grease the shims just clean them up
I have posi quiet ceramic pads on my IS. Cheap, low dust, and perform like most cheap ceramic pads. Low initial bite compared to semi-metallic. If it's your daily driver you'll be fine with just about any pad. Rockauto normally has the best prices available.
I put the posi quiet pads on my 350F a while back and could not be happier. I posted a thread in the "Suspension and Brakes" forum if you want more info. I have heard good things about the Akibono pads as well, but can only comment on what I have. No regrets here whatsoever. And Rockauto is definitely the place to get them.
There are also brake pads that will come with adhesive brake pad shims that require you stick on the shim to the brake pad backing plate. This doesnst require the use of disc brake lube, but you can still apply a thin coating on top of the brake backing plate. And of course clean and lubes sliders/pins are a must!
