Tuned 2015 IS350F from Dubai
Old 01-21-16, 02:52 AM
Bermuda
Bermuda's Avatar
Default Tuned 2015 IS350F from Dubai
Greetings from Dubai !
We have a tuner here in Dubai who does tune Lexus and Toyota ECUs.
I tuned my is350 with an AFE intake and gained 20whp versus stock.
Below is a run after the Tune.
I have more videos and a couple of races on my Youtube channel
The gains with the intake are noticeable and the car breaks traction more often
Old 01-21-16, 05:47 AM
Rudiculous
Rudiculous's Avatar
Do you have a dyno sheet?
Old 01-21-16, 12:09 PM
speedneed
speedneed's Avatar
Didn't I read somewhere on this Forum of a company selling a tune kit that gave you 20HP more. Only problem was the Lexus computer slowly compensated and the increase in HP was eventually lost.
Old 01-21-16, 12:20 PM
davyjordi
davyjordi's Avatar
didn't you post this exact thread a while ago to a tepid reception?
Old 01-24-16, 01:52 AM
ramlawih
ramlawih's Avatar
How much did it cost you to tune the car, and where did you do it?!
Old 01-25-16, 07:28 AM
dnasians
dnasians's Avatar
unless someone figures out how to turn off the 'learning' feature of the ecu, tunes on the stock ecu will eventually be lost.
there's tons of threads about lexus's adaptive ecu's, across multiple platforms, and why tuners don't tune them.
Old 01-25-16, 10:32 AM
Bermuda
Bermuda's Avatar
Nope I am not the same person
Old 01-25-16, 10:33 AM
Bermuda
Bermuda's Avatar
AED2,500 at Dubike Dyno Garage
Old 01-25-16, 10:44 AM
Bermuda
Bermuda's Avatar
There is nothing as such. At least with my Tune and friends who have the same tune.
I had this tune for around 3 months now and I do not feel any loss in power whatsoever. At first I tuned it on Bone Stock setup, then re-tuned it after the intake.
This is a proper ECU Remap with adjustments to the Timing, Air/Fuel ratio, Shift RPMs, Throttle response e.t.c.. not just a shadow mapping in the ECU.
Old 01-25-16, 10:46 AM
Bermuda
Bermuda's Avatar
This is not the same. ECU did not compensate itself or anything.
Old 01-25-16, 10:55 AM
Bermuda
Bermuda's Avatar
I have the dyno sheet when I tuned it Bone stock before the intake.
I will contact my tuner and try get the latest one after the intake with comparison to stock.
Old 01-25-16, 11:03 AM
jkonquer
jkonquer's Avatar
can you post the one comparing stock vs tune? at power/torque dyno, not speed dyno..
Old 01-25-16, 11:12 AM
nulex1
nulex1's Avatar
what is the cost of this tune and how do we get it here is us/can?
Old 01-25-16, 11:36 AM
Swacer
Swacer's Avatar
How many miles have you driven post tune? Have you had the car dyno'd following the tune, then again at 10k miles later?
My bets are that the ECU removes all gains eventually.
Old 01-25-16, 01:11 PM
anthonys2r
anthonys2r's Avatar
For what its worth, there's been some major developments in the ISF department in terms of tuning the past few days: https://www.clublexus.com/forums/cl-...e-finally.html
Quick Reply: Tuned 2015 IS350F from Dubai
