LED turn signal question
#31
Cconnors, which bulbs did you go with? The CREE bulbs I referenced that do not fit do not use a decoder... I'm guessing you went with the bulbs from VLED's?
I was looking for a plug and play bulb that would fit...no resistor, no decoder, etc.. The CREE bulbs were too long.
Please clarify where you got your bulbs and decoder
These are the exact ones I ordered. They come with the bulbs as well as the decoder. There are no LEDs that I'm aware of that are true plug and play without the hyper flash. The only way I know to have it look stock without that flash is either the decoder or resistor. I didn't mid dishing out a few extra bucks for the decoder since I'm not into splicing wires and all that. They look fantastic. I'll add a video shortly.
#32
http://store.ijdmtoy.com/Error-Free-...s-p/20-009.htm
The bulbs I had were the CREE 7440 with built in decoder and they're great/perfect in the front but too long to fit the housing in the rear.
I ordered the ones you referenced recently and just received them. Being you had success, I figure these will be the ones!
Thanks for the help!
