My winter tire setup...
So I have read many of the forums on winter wheels and tires and decided on the following setup.
RWC wheels from a local shop - 129$ each - 17X7, hubcentric
Yokohama Ig52 winter tires, 225.45.17 - $960 tax and installation included. I have used these tires on other cars and they are really good in the ice.
The tire dealer I use has so`me `clonable`TPMS sensors he will program and install for $60 each, tax in.
My IS350 is Atomic Silver - so now I am wondering if I should have bought the Anthracite or Black winter wheels instead of silver...too late I guess.
If you are in the montreal area and want details on this setup - PM me.
D
D
If you get the EZ-sensor 33500 TPMS, let me know if you get the tire pressures in the dash. I was told I'd get them, but I'm not...
The weird thing is that I will have them if the OEM sensors are aside the car when I put ignition on, and they will work as long as the car is not shut off... But I get no pressure readings of the OEM sensors are not near the car when starting it...
I don't get pressure readings if the OEM sensors aren't near the car upon start up. If they are near, I get the readings... Pretty weird...
No warning light, but I know it may take a while for it to appear so I can't confirm. Next I need to try and deflate a tire, to confirm if I'm getting the low pressure warning.
I'll go back to my tire shop cause I was specifically told I'd get the readings with their new software update.
will let you know on the TPMS
My tire dealer tells me they will work just like the OEM. AAnd I will not have to have them rebound to the car every season change. Its a shame that lexus did away with the 2 sets of tires settings that you used to be able to easily choose...I had that on my 2IS 250...
Well, I tried deflating a tire and I do get the tpms light in the dash... So the car does get the pressures, but simply won't display them... (having the OEM sensors near the car upon startup did show the pressures, and as I drove away, I indeed got a yellow pressure reading showing 25psi in the dash. But when I stopped and restarted the car, no more readings)
I am impressed with how quiet the Yokos are though, the ride is softer than with the stock 18s but the car still feels good.
D
Just came back from my tire shop and the sensors vendor acknowledged the problem. The new 33500 sensors did fix this problem with a bunch of cars, but not Lexus.
I did confirm that the system actually works and will display the tpms light if a low pressure is detected, but you won't get the readings in the dash.
D
D
Hi
Are those rwc wheels? Do you have pictures of them mounted on your car?
Thanks
kaslead
10-13-06 05:59 AM
