garage door opener
garage door opener
can someone point me in the right direction as to program my garage door opener. all the videos I've seen uses you garage door remote but i don't have a remote I'm trying to do it with just the red learn button but it doesn't work thanks
As far as you know you need the remote. You need to first sync the remote with the car, and than you can use the learn button on the opener to program the car. Thats how it was on all my cars.
I never used the remote. If the garage door opener uses rolling codes, you have to use the red button on the opener to begin the learning process. The instructions are in the manual for home link.
For first time training, press and hold the two outer HomeLink® buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.)
Position the hand-held transmitter 1-3 inches away from the HomeLink surface (usually located on your visor, overhead console, or mirror), keeping the HomeLink indicator light in view.
Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly.
When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
Press and hold the trained HomeLink button and observe the indicator light.
If the indicator light is solid/continuous, training is complete and your device should activate when the HomeLink button is pressed and released.
If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light, proceed with the following training instructions for a rolling code device. A second person may make the following steps quicker and easier.
Please use a ladder or other device. Do not stand on your vehicle to perform the next steps.
At the receiver (motor head unit), locate the “learn” or “smart” button (usually near where the hanging antenna wire is attached to the unit). If there is difficulty locating the training button, reference the device owner’s manual.
Press and release the “learn” or “smart” button (the name and color of the button may vary by manufacturer). NOTE: Once the button is pressed, there are 30 seconds in which to initiate the next step.
Return to the vehicle and firmly press and hold the trained HomeLink button for two seconds and release. Repeat the “press/hold/release” sequence up to 3 times to complete the training process.
If you can't find your remote to the garage door, you can also use the keypad that is located on the side of your garage (you know the one where you type in the code to get in?) that exact pad can be taken off with two screws and used in your car as a "remote" for pairing your garage door to your car.
