RAZO Shift Knob Installation
Thanks! It took some researching online but I'm happy with the results.
Haha that seems interesting, but not my style.
Not sure if it'll fit your GS, but this is the one I got. And as I mentioned, I haven't tried installing the boot itself because I just swapped out the ring/clip.
http://www.ebay.com/itm/291597382371?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
JDM Black PVC Leather Gear Manual Shifter Shift Boot W / Red Stitch Universal 2
How did you remove the OEM shift ****. I also bought after market part but did not know how to get the OEM off. I was afraid to break it . Any tips would greatly appreciated.
You just have to pull down on the boot where it connects to the **** and it'll come off. You have to add a little force so don't be afraid. Then you twist the **** to take it off.
As for the ring, you have to use the ring from the aftermarket cause the stock boot doesn't have a ring. However, I kept the stock boot with the aftermarket ring. When you flip the stock boot inside out, you'll see that the stock clip is held on with just a zip tie. Same with the aftermarket. The aftermarket ring is held on with a zip tie also. So pretty much you cut off the zip ties and swap them and then zip tie them again. I had to go to the hardware store to buy some really tiny zip ties though. You'll see when you take a look at it. Very simple.
no mods to the oem boot. I did however break off the clips that clip onto the oem ****. That allowed me to use the oem boot.
Originally Posted by leo877
This is my new shift ****. OEM style but different leather color. I am still waiting for the part to come.
