F-Sport 3IS Winter setup with 17in mags? Picture?
#122
Do you have the new version (33500) of EZ sensors installed ? I thought yours are able to display pressures.
https://www.clublexus.com/forums/is-...-wheels-2.html
Or you actually have the older version which actually resembles a OEM sensor in terms of form factor (actually it is smaller in every dimension).
On the other hand, a 33500 EZ sensor is actually much smaller and its form factor is like a half-sized OEM sensor. It is a dual-band TPMS sensor.
My winter wheel set for 2014 IS used to have older version of EZ sensors. The system works but couldn't display pressures per location.
After spending so much time (trying different updates from Bartec) during the past 2 years, finally my tire shop was willing to switch it back to the OEM sensors yesterday. The OEM sensors worked instantly the moment the tire shop programmed it. The individual pressure reading showed up instantly. The tire shop used the same programming data for 2014 IS from the same Bartec device.
#124
Probably due to the design of the spokes, your rims appear to be bigger which makes the look nicer.
#125
Anyway in my case, I have been waiting to get it work for 2 years. Too many going back and forth and disappointment. So I gave it up and requested the tire shop to switch to OEM ones. I really find the individual pressures on dash beneficial, especially during winter.
#126
The ultra weird thing is that it can actually read the pressures... If I start the car and my summer wheels are along side the car, I'll get some pressure readings, and they will stay there and update as long as the car is not shut off. But when the car is restarted, they won't show anymore...
#127
Agree completely with @AndyL. I perfer the OEM look and these look very clean. I daresay the color is almost an exact match to the OEM F-Sport wheels. Wish these were around when I got my snows last year.
#128
#129
Good way test would be to deflate one of the summer tires and see if the car picks that up and/or updates to the winter tire later during your drive.
#130
I think i may have the same sensors as you. They are clonable sensors. They dont have the pressure display number but that is because of the software the shop used to program my sensors. The guy at the shop told me that next year they should have the new software and if i wanted i can go free of charge to get them reporgrammes so the pressure number displays
Or somethimg of that nature
Thanks
#131
Doesn't this suggest the your car is picking up the summer set at start-up and then not communicating for the rest of the drive? I've experienced this before, as I used to keep the summer set in the garage. Basically, your car is just picking up the summer pressures then isn't it?
So the car is actually able to get the pressures and display them, but won't for some unknown reasons.
#132
The pursuit of F
These are the best 17" aftermarket wheels on 3IS I have come across so far. Wish I were aware of it before. I have the 17" OEM wheels from 2IS and have the same tires (Michelin X-ice 3 225/45R17)/
#133
Car does read the summer tires pressure at startup, but if I drive away and deflate a tire, I will see the lower pressure get updated from the cloned sensors... Even if I don't move the car, the pressure readings will alternate between the summer and winter tires... So the car is actually able to get the pressures and display them, but won't for some unknown reasons.
Did the tire shop clone the actual sensor IDs from the summer set to the winter set?
#134
Nice package
Im getting confused as there are so many white cars here
Is this price cad? Or us $ ?
Thanks
