brakes on IS200t
Old 08-19-15, 05:53 PM
stlgrym3
stlgrym3's Avatar
Default brakes on IS200t
are they gonna be the puny set IS250 carries or same as the IS350?
Old 08-20-15, 07:59 AM
stlgrym3
stlgrym3's Avatar
Originally Posted by PatrixUSA
According to Lexus.com, here are the specs for each:
2016 IS 200t RWD (same for f-sport)
Two-piston calipers with 11.7-in ventilated discs (front), 11.4-in ventilated discs (rear)
2016 IS 350 RWD (same for f-sport)
Four-piston calipers with 13.1-in ventilated discs (front), 12.2-in ventilated discs (rear)
so same brakes for 200t as the 250 then. umm, that's a total turn off for me. can't stand the look of the puny caliper on the 250 brakes.
Old 08-22-15, 11:24 AM
USB3IS
USB3IS's Avatar
not sure if the "puny" brakes actually affect everyday performance to a noticeable degree. Although the bigger brakes do look better and are easier to maintain.
Old 08-22-15, 11:27 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Just checked the NCF book and repair manual. The IS200t, 300 and 350 all now have the 4-piston 13.1" front brakes.
I believe Lexus.com is a mistake.
Jeff
Old 08-22-15, 11:44 AM
USB3IS
USB3IS's Avatar
If that's the case that's awesome! Hopefully the IS300 hp is also a typo or under-rated and it's the same unit as the 350 LOL
Old 08-22-15, 12:26 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
It appears the IS300 AWD has the same engine as the IS350 but detuned, so the numbers are correct.
Jeff
Old 08-22-15, 12:37 PM
SummerRain
SummerRain's Avatar
I really don't get it. Same displacement, same MPG. Why are we going for less hp.
Old 08-22-15, 02:13 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Slightly cheaper.
Jeff
Old 08-22-15, 02:32 PM
brendanf
brendanf's Avatar
Perhaps it is for emissions...
Could it be drivetrain losses.. There has been talk of an 8spd next year too.. Is the IS300 getting the 8spd or sticking with the 6spd...
Old 08-23-15, 08:36 AM
JDR76
JDR76's Avatar
Received 1,603 Likes on 1,021 Posts
Technically it replaces the IS250 AWD, so it's a bump in HP.
Old 08-28-15, 03:22 AM
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
Jeff
That's great news! They're getting more serious.
Old 08-28-15, 08:11 AM
EthanV
EthanV's Avatar
I checked the lexus website
Old 08-28-15, 09:59 AM
stlgrym3
stlgrym3's Avatar
^^^ are you sure those are not for the '15 IS250? U.S. spec IS200t has even publicly released yet
Old 08-28-15, 10:44 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Lexus USA has updated their website for the IS200t. It no longer lists the IS250.
Still, the website is probably wrong. They've made mistakes like this in the past as well. The IS hasn't had 2-piston front calipers since the IS300 in 2005, but they kept listing it that way for the IS250 for a long time.
Jeff
Old 08-29-15, 05:24 AM
Imprezario
Imprezario's Avatar
The spec chart from Japanese Lexus website says that:
ブレーキ フロント:対向4ポッドキャリパー・φ334mmスパイラルフィン式ベンチレーテッドディスク
(高摩擦ブレーキパッド*2付)
"Brakes front: oncoming 4-pod Caliper・φ334mm spiral fin. bench press disk
(High-friction brake pads * to 2)"
And
リ  ヤ:φ310mmベンチレーテッドディスク
"Rear: φ310mm bench press disk"
http://lexus.jp/models/is/specificat...00t/index.html
Looks like a real deal )
Quick Reply: brakes on IS200t
