Door handle removal... Any help would be apreciated
Hi everyone, I am trying to remove the door handle on my 2015 IS and there in no information on how to do this for the 3 gen. So far Ive been able to almost get it out but as you can see from the following pictures, the blue circle is holding me down. I already removed the two red circles, but i have no idea how to finish disconnecting that blue circle so that the handle can come out. The handle is loose already freely to move front and back and a bit towards the outside but no luck with the connector... If anyone have an idea pls let me know. From the outside you can see the white connector still attached and it doesnt get loose no matter how much i pull.
sorry for the late post
Hope this still helps, I made it a while back when I was wrapping the handle gloss black. For the connector all you have to do is push that white tab (the blue one you circled) in (use a small flat head screwdriver and just push the tab in), don't touch any other tabs and take your time doing it so you don't break it.
erayd8
11-06-02 06:44 PM
