too much engine oil?
Old 08-18-15, 12:17 AM
tea
tea's Avatar
Default too much engine oil?
had my first oil change by the dealer this weekend and they had put in way too much oil, i believe they said it was 7.7 quarts. So they redid the oil change and put in 7 quarts, or so they say. When I check the dipstick, it's about 1.5 cm above the high level marker. Is this alright or should I ask them to redo it again? I believe it requires 6.6 quarts, so will the .4 extra quart cause any harm?
Old 08-18-15, 12:18 AM
3ISRC
3ISRC's Avatar
You will be fine.
Old 08-18-15, 12:46 AM
aTeAse
aTeAse's Avatar
A quick search on google states that an excessive amount of engine oil may cause various damages over time.
I recommend going through normal oil changing procedure to verify if the amount is accurate.
Old 08-18-15, 12:49 AM
toeknee88
toeknee88's Avatar
sorry but 3ISRC has it wrong. It is bad to have too much oil in the engine. Having too much oil in the engine could cause certain engine seals to go bad quicker and possibly the crankshaft to spin off balance. Theres explanations all over the web. So just google it if you want to learn more in depth about it
Old 08-18-15, 07:24 AM
3ISRC
3ISRC's Avatar
Look I'm not saying it's good to over fill. But we are talking what .3-.4 to be exact? I wouldn't worry about it is the point I'm trying to get across.
Old 08-18-15, 09:37 AM
DrHorrible
DrHorrible's Avatar
Eventually if you overfill enough, it will overflow up to the crank shaft and bad things can start happening as the crank shaft stirs up the oil. But like 3ISRC said, something like 0.4 qt will not be enough to fill it up that much.
Old 08-18-15, 10:08 AM
3ISRC
3ISRC's Avatar
Talking
This is exactly my point. I'm trying to help OP on not wasting his time over this. .4 is nothing to worry about and will soon be consumed. There's always a small wiggle room I would think to allow situations like this. Now if it was 1qt that's a whole another concern.
Old 08-18-15, 10:10 AM
Dark9t316
Dark9t316's Avatar
Take it back to the dealer
Old 08-18-15, 10:14 AM
GSteg
GSteg's Avatar
0.4qt? I wouldn't sweat it. Just don't do any full throttling.
Old 08-18-15, 11:30 AM
gvan1998
gvan1998's Avatar
I rather have .4 less oil than .4 more oil
Old 08-18-15, 04:11 PM
aTeAse
aTeAse's Avatar
Drain the oil, and verify the right amount in the car. Do not take Horrible advice.
Old 08-18-15, 05:28 PM
tea
tea's Avatar
thanks for the advice. I decided to let it be for now.
Old 08-18-15, 05:57 PM
3ISRC
3ISRC's Avatar
Horrible advice, smh. Come on man do you actually think the dealer put precisely 6.6qt of oil at all times?
Old 08-18-15, 06:31 PM
Dark9t316
Dark9t316's Avatar
I think if he's worried, then take it back to the dealer and get it taken care of, sometimes that's what you do to get a peace of mind.
Old 08-18-15, 09:26 PM
DrHorrible
DrHorrible's Avatar
For what it's worth I have overfilled by a quart on my cars and literally nothing happened. Cars have tolerances, you know. If it broke with a simple half quart extra then everyone's cars would be taking a **** on the roads from the average dullard.
Quick Reply: too much engine oil?
