What to look for in a used is 350 f sport?
I've searched, and can't find anything completely relevant, so figured I'd ask.
I'm going to (hopefully) purchase a 2014 350 f sport on Saturday, but I haven't seen the car yet. It's got a clean carfax and auto check, but no service records on either. The salesman says there are none with the car either. I understand a lot if services don't get reported as I do all my own service too.
Car's got 20k miles on it and is a lease turn in. Coming from Acura products, I'm wondering if there's anything I should take a close look at in particular on l/t products. I can already tell by the pictures the tires need replacing.
Thanks in advance!
Thanks in advance!
Considering that first 2 services are free from Lexus you should see if the dealership has any service info for the car nor carfax related. Nothing particular sticks out on these cars to look out for though, just watch for the normal signs of wear and other things
If you're a bit picky, you can keep an eye out for the front two seats. There was a thread on here a while ago about there being a crease where your butt would be.. Cosmetic but still may bug you if you spend so much money on a car and it already has this cosmetic problem not even 2 years in.
Seat thread: https://www.clublexus.com/forums/is-...e-problem.html
Maybe also test out the navigation to see if it's slow; there's a fix but just make sure software has already been updated so you don't have to deal with the headache of bringing it back to the dealer.
Navigation: https://www.clublexus.com/forums/is-...-resolved.html
This particular vehicle isn't CPO'd from the dealership?
I recently picked up a 14 350 f sport. As already mentioned if the infotainment system is slow the latest update from the dealer should fix it. It did for me anyway. What I didn't expect was the ticking noise from these engines. Sounds a bit like a diesel. But that's just the direct injection. Sorta bothered me a first but I'm used to it now.
CERTIFIED! * Q-Certified for up to 2 years and 100,000 mile warranty * Rental Reimbursement * 128 point inspection *
You should be able to get the service history yourself from lexusdrivers.com. Create an account, log in and add the car to your cars with the VIN, then select service history. Any service done by Lexus will appear here. You can do this for any car your are interested in as long as you have the VIN number.
check the inside shoulder of the front tires.
when i bought mine it was noted that the tread was good but i needed tires 5k miles later. I was planning on getting new tires anyway since the OEM ones arent that good but it was a cost i wasnt expecting.
