Pulled over by a cop for no lights!
Driving home from work around 10pm. Leo started explaining that i had no taillights on but the brakes worked. Ugh, he was right. I came home and found out my parking light fuse under the steering column was blown. I replaced the mini 10-amp fuse with a spare and they started working again. Then later, they stopped working again. Has anyone else run into this problem? Only thing i have installed electronic upgrade wise is after market LED fog lights(which went out with the parking lights but both came back on with the new fuse) and Navi bypass. What could it be?????
Former Sponsor
If the fogs go out when the tails do, then they are on the same circuit. Since they after market, suspect them first. They could be drawing more current than the factory bulbs.
I do suspect the fog lights as well. I should've tried driving around with the fog lights deactivated for diagnostic purpose but i was just too quick to blame the fuse. I'm going to take them out, replace the fuse again and post the result later! i really hope this will fix it. Thanks for all your input
Wasted good amount of time today trying to address the light issue. First thing i did was removed the aftermarket LED fog lights (direct fit which by the way worked fine since the day i installed it 11/13) and replaced the fuse. The parking lights came on for about 5-10 mins then blew the fuse. Ive reinstalled the factory fog lights with a new fuse and same thing. I'll be wasting MORE time now going to the dealer and have them sort it out. Ugh, my first nuisance with a lexus. I wonder what it could be... i hate gremlins!
By the way i did check all the wirings around the takeda intake bracket on the passenger headlight and all the insulations seem to be fine with plenty of room. Even all the wirings for the fog light seemed clean.
Yea i felt the same way.. about the dealership finding out something that was my fault. Plus i hate other people touching my car for something simple. So last night i got a hold of an electrical diagram for the parking light system and put my thinking cap on and did some thorough check-out. During inspection of the passenger side headlight harness, i found a little scruff mark on the wire loom that was touching the takeda/greddy intake bracket for the air filter. It didn't seem to be cut but once i removed the loom and got to look at all the wires. Two black wires were showing copper!!! Looking at the diagram, those black wires run to the passenger headlight marker light....
Wow.. what a gremlin that was and gpxluke was right from the first suggestion! That's the reason i love this forum, we all learn from each others experience and mistakes and can be quiet useful. Thanks everyone for participating, I can save a trip to the dealer now. I've included a picture of the exposed black wires. Those with takeda/greddy intake bracket, be aware of this common problem and make sure you leave the wires clear from that sharp bracket.
image by , on Flickr
Former Sponsor
Surprised to hear that even with the rubber seal it penetrated the wire loom.. i was going to put some electrical tape around the edges. But now I'm going to relocate the wiring harness by removing some of the factory tie downs. Everyone with takeda intake bracket should check their harness too. Mine took about year and a half to show an intermittent problem. I wonder what could've happened if it shorted out some other wires than just my parking lights.. yikes. Aftermarket upgrades come with a price haha
LasVegasGS
SC- 1st Gen (1992-2000)
02-21-05 12:01 AM
