Recommended PSI for summer tires/Michelin PSS for 3IS
Old 05-12-15, 07:44 PM
AndyL
AndyL's Avatar
Default Recommended PSI for summer tires/Michelin PSS for 3IS
For those who have Michelin PSS or similar high performance summer tires on 18" rims for 3IS, I wonder if you follow the manufacturer's recommendation, ie. 36PSI for front and rear (225/40R18 and 255/35R18)
The reason for asking is that I was told by my dealership that the pressure should be set to 38PSI for all 4 summer tires as they claim it would reduce the chance of uneven wear for such high performance summer tires. On the other hand, my tire shop says I should stick with what is said on the door.
Old 05-12-15, 07:59 PM
EZZ
EZZ's Avatar
Originally Posted by AndyL
For those who have Michelin PSS or similar high performance summer tires on 18" rims for 3IS, I wonder if you follow the manufacturer's recommendation, ie. 36PSI for front and rear (225/40R18 and 255/35R18) The reason for asking is that I was told by my dealership that the pressure should be set to 38PSI for all 4 summer tires as they claim it would reduce the chance of uneven wear for such high performance summer tires. On the other hand, my tire shop says I should stick with what is said on the door.
Stick with what's on the door. I've had Pilot Sports for 11 years and never heard that from anybody.
Old 05-13-15, 09:45 PM
Sito514
Sito514's Avatar
should be 36
Old 05-14-15, 08:19 AM
EffedSport
EffedSport's Avatar
i keep them around 36-38 range, you should be fine
ixel
RC F (2015-present)
10-27-17 07:33 PM
Hulk311
Wheels, Tires & Brakes Forum
06-20-15 03:46 PM
carrwash13
03-17-11 03:42 PM
larryw01
CL of Hawaii
05-19-09 02:38 PM
slawek65
11-19-04 01:59 AM
Quick Reply: Recommended PSI for summer tires/Michelin PSS for 3IS
