Aftermarket Wheel Showcase - 3ISx Exclusive
Old 12-14-16, 07:32 AM
  #856
JorgeNery
JorgeNery's Avatar
19" Concept One CS16's. Not sure if I want to lower it yet. It's a commuter.
Old 12-14-16, 12:22 PM
  #857
dnasians
dnasians's Avatar
Originally Posted by mjh09e
Hey everyone, I just lowered my 2016 IS350 F-Sport on Swift springs this Saturday, December 9th 2016.
I ordered a set of F-Sport Forged 19s that are 8 et 40 in the front and 9 et 40 in the rear.
I plan on running Michelin Pilot Super Sports with a fat square sidewall and I have passengers in the rear maybe twice a week.
Any suggestions on tire size??
I've found that most people are running either 225/35/19 or 235/35/19 front and 255/30/19 or 265/30/19 rear.
I'd like to go as wide as possible, while still keeping the car drivable without having to worry.
All suggestions and comments much appreciated.
Thank you,
Mike
Can't go wrong with OEM wheels!
Fronts: 19x8+40: these are very conservative specs (too conservative). I'd recommend getting a 10-20mm spacer to push the wheel out a little more. to make the wheel sit more flush to the fender. If you want a fat tire in the front, I'd stick to getting a spacer that's less than 15mm. I recommend a 15mm spacer with 235/35 tires. You can go up to 245/35/19 without rubbing issues (max 10mm spacer).
Rear: 19x9+40: These are decent specs for the rears, especially if you want a fat tire. I recommend getting 265/30. You can go up to 275/30/19 without rubbing issues.
Edit: And since you just lowered your car, did you get an alignment? I highly recommend getting rear camber arms (SPC makes them, and they're reasonably priced) and getting it aligned. Maximize the life out of those pricy rear tires!
mjh09e (12-14-16)
Old 12-14-16, 01:17 PM
  #858
mjh09e
mjh09e's Avatar
Thumbs up Thank You!
Thanks for the advice. I currently have 20mm spacers on all four corners. If I keep the 20mm spacers in the front, should I go with 225/35/19 in the front? I don't necessarily care to have beefy tires in the front.
As for the alignment, I plan on doing that as soon as I get the tires mounted. I only lowered my car about five days ago, so I figure it can use a few more days to settle.
Would it be safe to say a good set-up to go with is 225/35/19 front and 265/30/19 rear?
Thanks again for the help 👍🏼
Old 12-23-16, 12:03 PM
  #859
derrock89
derrock89's Avatar
Default 19" Vorsteiner V-FF 103s
Hey guys new user here. I came from the modded Audi community, but have had a stock IS for a year now. I finally pulled the trigger and bought some Vorsteiner V-FF 103s and Eibach Pro Kit springs.
So far I've been very happy with them. The concavity in the rear looks great and the red center caps really stand out!!
The following 2 users liked this post by derrock89:
matttev (12-30-17), sixbanger (11-11-18)
Old 12-25-16, 09:02 PM
  #860
3actual
3actual's Avatar
Originally Posted by derrock89
The car looks great. Is your car not an fsport model? Your brakes look really small and those front calipers are different than mine.
Old 12-26-16, 03:08 AM
  #861
Matroushi
Matroushi's Avatar
The 250 has those smaller brakes.
Old 12-28-16, 06:16 PM
  #862
Jmaarc13
Jmaarc13's Avatar
Default 2016 Lexus IS200T FSPORT
New to Club Lexus, but not new to owning one as this is my 3rd. Originally owned a 2001 is300 and bought my wife a 2014 is250. Here is my IS200T FSPORT, riding on the following:
Vossen CVT
F 235/35/19
R 265/30/19
F 19 x 8.5
R 19 x 10
RSR Coilovers
FSPORT exhaust.
Siebon FP Type from lip being installed this weekend.
no rubbing at all whatsoever and "yes" it's a daily commuter. Originally had FSPORT springs but made the jump the the RSF Coilovers. Set on full soft it actually rides better then stock.
IreneIS350 (01-16-17)
Old 12-28-16, 08:29 PM
  #863
TLIS350
TLIS350's Avatar
What are your wheel offsets Jmaarc13?
Old 12-28-16, 10:43 PM
  #864
Ray20213
Ray20213's Avatar
Default Just have to say....
Vossen CVT
F 235/35/19
R 265/30/19
F 19 x 8.5
R 19 x 10
RSR Coilovers
FSPORT exhaust.
JUST WOW!!!!congrats I have to admit I never really liked this color that much, but with this set up it looks perfect!! awesome choice looks very very nice !!
Jmaarc13 (12-29-16)
Old 12-29-16, 05:17 AM
  #865
Jmaarc13
Jmaarc13's Avatar
Here you go;
F 19 x 8.5 32 mm
R 19 x 10 42 mm
i just called Vossen myself and asked what would be the largest I could go without rubbing. I even had the shop that installed the RSR Coilovers say that it would run when lowered. I went ahead and told them I would deal with it and after the install they were even surprised on the perfect fit. No rubbing!
ToDesi (12-29-16)
Old 12-29-16, 06:25 AM
  #866
link13
link13's Avatar
Vossen CVT
F 235/35/19
R 265/30/19
F 19 x 8.5
R 19 x 10
RSR Coilovers
FSPORT exhaust.
Love this. Car looks incredible! Nicely done
Old 01-11-17, 10:17 AM
  #867
Cheeb
Cheeb's Avatar
Time to get some wheels and tires but I have a quick question about sizing/rubbing on an AWD 350. Here is what I have planned:
Front: 19x8.5 ET35 235/35/19
Rear: 19x9.5 ET35 265/30/19
I plan on installing RSR downs before I mount this setup. This is a daily driver. Thanks in advance for your advice!
Old 01-11-17, 10:37 AM
  #868
Phamkq
Phamkq's Avatar
Originally Posted by Cheeb
Quick fitment question:
Should I have any fitment/rubbing issues running 19x8.5 (235/35) squared with RSR Downs. 2014 IS 350 AWD. Thanks in advance!
no rubbing whatsoever. If your wheels offer 9 wide instead of 8.5, I'd jump on it
Old 01-16-17, 09:34 AM
  #869
ericbd
ericbd's Avatar
2015 RC350 fitted with 20 inch Blaque Diamond BD-23's in bronze w/ chrome ss lip
Old 01-18-17, 10:56 AM
  #870
seoulstar
seoulstar's Avatar
Has anyone seen or have Gram Lights 57Transcend on a 3is?
Quick Reply: Aftermarket Wheel Showcase - 3ISx Exclusive
