Aftermarket Spring Installation Question
Old 06-23-14, 08:27 PM
LEXUS1904
LEXUS1904's Avatar
Default Aftermarket Spring Installation Question
Hello CL,
For everyone who has aftermarket springs. How was the installation? Was there any complitcations? I know in Sport + mode tightens up the suspension and i was wonder if theres something special i should look out for for installation. I just ordered a set of RSR Down springs and I'm just wondering whether to have the dealership infall them, a local shop, or doing it myself with some friends. Thanks in advance!
Old 06-23-14, 10:16 PM
Mr_VFS1
Mr_VFS1's Avatar
Have a local shop install them and do an alignment. You shouldn't have any issues with springs.
Old 06-24-14, 11:16 AM
L0ngJ0hn
L0ngJ0hn's Avatar
I thought this car had no camber control. What kind of alighnment do they do?
Old 06-24-14, 11:25 AM
Silec
Silec's Avatar
Originally Posted by LEXUS1904
Hello CL,
Installation is not that difficult, the front is identical to the 2is with a exception of a sway bar that you need to unbolt in order to drop the LCA. As for the rear, I believe it was 4 bolts that is connecting the LCA to the brake assembly that you will need to undo. You will also need a spring compressor.
No adjustable camber kit on the car but they still can adjust the toe but I wouldn't do it right away, wait until the suspension settle to do the alignment.
Old 06-24-14, 11:48 AM
JB5674
JB5674's Avatar
What Silec said. I waited about a week and a half for my suspension to settle. Camber will come close, but be out a .5 degree or so. Toe and thrust angle etc will have to be adjusted. As well, I believe that FIGS Engineering has some components for adjustment.
http://shopfigs.com/v1/index.php?rou...tegory&path=89
The Upper and Lower CA mounts look like you can gain a degree of adjust-ability. BUT, install for these looks to be a PITA and a press is a must. I had all these mounts in my VW. If I were to do my springs over.....I would have spent the extra coin for these items. Rethinking this when I do Coils.
Radslyfe
Northeast
04-02-17 06:30 PM
plastus
Northeast
07-26-16 08:19 AM
njlexusguy
RC - 1st Gen (2015-present)
07-06-15 03:41 PM
jjwalker
Suspension and Brakes
16
06-04-06 08:45 AM
Seattle350
05-09-06 06:37 PM
Quick Reply: Aftermarket Spring Installation Question
