removing center console
Old 06-09-14, 09:05 PM
fiendskill
fiendskill's Avatar
Default removing center console
Any ideas on how to remove the center console? Like that area by the shifter and rectangular spot before it? Im wanting to add some felt or something to help stop all the creaks I hear while driving.
Old 06-09-14, 09:59 PM
JCWong
JCWong's Avatar
do u have navi? I find the "creaks" come from the mouse area, first I thought it's from the shifter but once I put a little pressure on the mouse and press the while hand rest part of the mouse down the creaks seem to go away or lessens. I'm planning to take it apart soon too to put some pad/cushion of some sort to eliminate the annoying sound
Old 06-09-14, 10:04 PM
qtmac
qtmac's Avatar
this will help you
Old 06-10-14, 11:56 AM
fiendskill
fiendskill's Avatar
Originally Posted by qtmac
Thanks. You think itll be the same for the 2014 version? And is there anything softer then that flat head he.was using?
Old 06-10-14, 12:53 PM
moose66
moose66's Avatar
Why not just take it back to the dealership and have them fix the issue? That's what I did. Mentioned it at the 1K service and they fixed it. Haven't heard one squeak since then, as the car approaches the 6K mileage point.
Old 06-10-14, 01:03 PM
4TehNguyen
4TehNguyen's Avatar
not sure if its been posted online but the instructions to install the beatsonic navi bypass is how you get access to the center console. Not sure if the PDF of the instructions are online
Old 12-06-14, 05:54 PM
GregZ3IS
GregZ3IS's Avatar
Any info on how to do this on the 2014-2015 models? My center console looks a lot more fragile than the 2is center console.
Old 12-06-14, 06:37 PM
RoiteTrom
RoiteTrom's Avatar
If it were me, I would had used the screwdriver or knife wrapped in clear tape so I won't scratch the console.
Old 12-06-14, 07:55 PM
AndyL
AndyL's Avatar
Generally, interior materials are very prone to scratches and marring. Better be safe than sorry. Mask the areas with good masking tapes, preferable the ones for automobile such as the 3M green tapes. Screwdrivers with clear tapes may still mar the surface if too much pressure is applied or the tip of the screwdrivers are not adequately taped. You could also find some dash removal tool set as well.
Here is a link which shows pictures of taking the centre console apart for the sake of a similar hack.
https://minkara.carview.co.jp/userid...9467/note.aspx
Old 12-06-14, 08:08 PM
nitrox05
nitrox05's Avatar
I did the same thing. Dealer fixed it by adding felt
Old 12-07-14, 06:35 AM
hades281
hades281's Avatar
I'm doing this from memory... I can get you part of the way.
Attached Thumbnails removing center console-diy1.png   removing center console-diy2.png   removing center console-diy3.png   removing center console-diy4.png
Old 12-07-14, 07:26 AM
AndyL
AndyL's Avatar
That is a good illustration! Very great efforts. I save the pictures as a handy reference
aTeAse
04-18-14 12:39 PM
snook
SC- 1st Gen (1992-2000)
11-15-09 06:48 PM
hawaii5b
GS - 1st Gen (1993-1997)
05-03-05 05:21 AM
Quick Reply: removing center console
