A/C system not coming back on after ignition
My service advisor said, "Yep, it's getting hotter out. It takes longer." I wanted to say "Really? You don't say." But just expressed disagreement and ended the conversation.
I feel like my A/C system is losing system pressure and having to repeatedly build it back up before starting to work. This problem is easily repeatable, in fact it did it just an hour ago. The car sat all night until I started it around 3PM. I've had three ISs before this one, one 1IS and two 2ISs, and none behaved as this one does.
PS - I have the IS 350.
I am glad someone posted about this. I just called to complain to my service advisor about my air conditioning this past week. My issue is that if the car sits overnight the compressor seems to take an immensely long time to turn on after starting the car. I'll have had the car running for up to a minute and a half before the air gets cool, and it doesn't do so smoothly, it gets cold all-of-a-sudden.
Even when my AC is not on it would simply turns off completely when I shut off the car. Or in the case climate system not coming back on when starting car as if I had turned it off before shutting down the car.
itskwilson
05-15-17 02:37 PM
Ktreece777
01-17-13 04:31 PM
