2014 IS350 F Sport V.S. 2006-2012 IS350
Old 08-04-15, 02:42 PM
  #31
LH1
LH1's Avatar
Its disappointing how much slower the 3IS 350 is compared to the 2IS 350. There are things I really like about the 3IS 350 but if there isn't some type of engine update/upgrade for the 2017 model year I'm checking out.
Old 08-04-15, 08:13 PM
  #32
atomic350
atomic350's Avatar
Originally Posted by JDR76
You're not off base. I believe this is why you can find tests showing the 3rd gen IS350 AWD models reaching 60mph quicker than the RWD models. The AWD models still retain the 6 speed, and reach 60 in second gear. The 8 speed models reach 60 in 3rd, meaning they have one more shift to get to 60.
As I recall, Motor Trend tested the IS350 AWD model at 5.3 seconds and the IS350 RWD model at 5.6. Note that Motor Trend believes this is a result of the better launch by AWD models, but I think the 2nd shift in the 8 speed has a bigger impact.
I can concur. My non-f sport AWD beats f-sport everytime. The AWD even feels faster when driven(0-60mph and 1/4 miles) And you guessed it, its all in the gearing and the final ratio of the 6 speed.
Old 08-05-15, 12:15 AM
  #33
marky678
marky678's Avatar
BTW, 3IS 350 RWD is faster than RC350 but still slower than 2IS 350.
Old 08-05-15, 05:26 AM
  #34
EZZ
EZZ's Avatar
Default 2014 IS350 F Sport V.S. 2006-2012 IS350
Originally Posted by marky678
I don't know if they tested optimally. If you manually shift at redline, don't you get better results as the full auto shifts way too early. Also if you leave trac on and put it in manual mode, I believe the tranny will shift at exactly redline and get better results. Can anyone confirm this?
The RC was pathetically slow. What is up with that car? Isn't it the same as the IS?
Old 08-05-15, 08:48 AM
  #35
Nigel-JDMParts
Nigel-JDMParts's Avatar
Originally Posted by D7000
Check this video out.
-On. Side note, I still haven't understood as to why Lexus didn't increase the HP of their 2GR-FSE to 335HP? As that motor is easily capable of such numbers.
At least to compensate for the excessive weight and pathetic gearing of these new generation spindle Lexus
2008 Lexus IS350 vs 2015 RC350 F Sport Drag Race - YouTube
That is sad watching this video…...
Originally Posted by 604981GT4
I'll add in my experience.
I've raced against my friend who has the the 3IS and the outcome is pretty much the same as the video posted below. There was no competition..it was like racing against an IS250 . I even gave him a head start and I reeled him in easily within seconds.
I'll try to set up another race with him and get it on video. Its too bad the last time we raced the batteries ran out on the go pro. I had no idea the go pro batteries drain so fast.
I'll be heading to the track in a few weeks and I"ll post my results.
Will wait for your video.
Originally Posted by Sexis350
As a 3is owner, i must say, that is lame.. newer and has less performance speed wise.
Exactly!
Originally Posted by WillK
I don't know the gearing for the 3IS but I would imagine it has to do with the extra tranny gears. The 3IS probably needs another gear to hit 60. Just an uneducated guess...
I hope the 3rd Gen will do better on the highway, maybe some people can take some video.
Old 08-05-15, 08:50 AM
  #36
Nigel-JDMParts
Originally Posted by DjRiDe
Sup Nigel, I can definitely say my 2011 IS350 was faster than my 2014 IS350. The 2014 just doesn't pull off the line as fast as my older one. I kind of miss my 2is for that reason - but i do like the perks of everything else on the 2014+
I know……everything is good, except it is slower...
Old 08-05-15, 09:17 AM
  #37
604981GT4
604981GT4's Avatar
That is right - I've tested can confirm this with my friend's 3IS . If it's left in auto mode it will shift at 6000 - 6200 rpm. In manual mode, you can control the shift point and shift at the redline. Of course, there is a risk of hitting the rev limiter if the timing is off . When we raced with my 2IS, I beat him all the time regardless if he used auto or manual...but auto mode seems like it's a bit slower, not much though.
In the 2IS auto mode, it will shift right at the redline 6500 rpm in auto mode.
I'm not sure why Lexus would do this for newer cars 3IS and up. Let's say that you're in auto mode and you need full throttle, the engine is held back by the early shift point. You'll need to shift into manual to do that and sometimes there just isn't time for that. I'm guessing it has to do with the weight gain and the gearing. It's the same story with the RCF vs the ISF. RCF gained weight and needed another 50 hp to make up for the difference and yet the ISF is still at least as fast or faster in the 1/4 mile.
We've tested the 0-60 and it's about 4.8 for my 2IS and it's 5.8 for his 3IS
Old 08-05-15, 11:25 AM
  #38
marky678
marky678's Avatar
Shifting at 6000 or 6500 won't make any big difference, it won't make 3IS 0-60 from 5.8 to 4.8. The only reason 2IS is faster It's due to gear ratio (3IS need to shift to 3rd gear to reach 60). If 3IS swap with 2IS's rear differential it will make 0-60 quicker. Several ISF owner did the swap and has confirmed to be quicker.
2IS RWD 350:
1st. 3.52
2nd. 2.04
3rd. 1.40
4th. 1.00
5th. 0.72
6th. 0.59
Final Drive: 4.083
3IS RWD 350:
1st. 4.6
2nd. 2.72
3rd. 1.86
4th. 1.46
5th. 1.23
6th. 1.00
7th. 0.82
8th. 0.69
Final Drive: 3.13
Old 08-05-15, 11:37 AM
  #39
JDR76
JDR76's Avatar
Received 1,603 Likes on 1,021 Posts
That's a bit slow for a 3IS. Is his RWD? Slowest I've seen from any testing has been 5.6 seconds on a RWD model.
2IS:
1st. 3.52
2nd. 2.04
3rd. 1.40
4th. 1.00
5th. 0.72
6th. 0.59
Final Drive: 4.083
3IS:
1st. 4.6
2nd. 2.72
3rd. 1.86
4th. 1.46
5th. 1.23
6th. 1.00
7th. 0.82
8th. 0.69
Final Drive: 3.13
Just for completeness, it should be noted that your comments here only apply to the RWD IS350. The AWD model uses the 6 speed transmission.
Old 08-05-15, 12:02 PM
  #40
marky678
marky678's Avatar
Yeah thats right, thanks for clearing up.
Old 08-05-15, 12:40 PM
  #41
604981GT4
604981GT4's Avatar
Yeah it's the RWD model. Test was done on a hot day at a higher elevation so that could explain the difference.
Old 08-05-15, 01:05 PM
  #42
EZZ
EZZ's Avatar
I still don't understand why the RC was so slow? Was it new? Was it tested in similar conditions versus the IS?
Old 08-05-15, 01:12 PM
  #43
604981GT4
604981GT4's Avatar
The effective gearing is pretty close between the 2 cars with the 3IS having more aggressive gearing when you multiply the final drive with the transmission ratio. In fact, my 2IS also requires a shift to 3rd before hitting 60...similar to this video... Maybe the 3IS is slower due weight gain?
2IS RWD 350:
1st. 3.52
2nd. 2.04
3rd. 1.40
4th. 1.00
5th. 0.72
6th. 0.59
Final Drive: 4.083
3IS RWD 350:
1st. 4.6
2nd. 2.72
3rd. 1.86
4th. 1.46
5th. 1.23
6th. 1.00
7th. 0.82
8th. 0.69
Final Drive: 3.13
Old 08-05-15, 01:23 PM
  #44
JDR76
JDR76's Avatar
I don't yet have a good feel for average RC350 times yet, but there is a lot of variability from what I am seeing. About the best I've found is 5.7 seconds in this C&D article:
http://www.caranddriver.com/reviews/...ed-test-review
C&D tested the IS350 RWD at 5.6 seconds.
In the Lexus Press Release Product Information sheets, they list the RC as being 155 lbs heavier than the IS350. Car and Driver stated 189 lbs. I could see that being enough to make the difference in .1 second.
However, Car and Driver also tested one at 6.0 seconds.
http://www.caranddriver.com/comparis...e-specs-page-5
Old 08-05-15, 01:25 PM
  #45
JDR76
JDR76's Avatar
I don't think the weight difference between 2IS and 3IS is enough to make that kind of a difference. 66 pounds on IS350 RWD models, 32 lbs on IS350 AWD models, per Lexus.
Quick Reply: 2014 IS350 F Sport V.S. 2006-2012 IS350
