DIY radar detector and Blackvue camera installation - Page 6 - Club Lexus Forums
Old 12-15-14, 01:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Thread Tools Search this Thread
Old 07-16-14, 11:25 AM   #76
HumanMale
Quote:
Originally Posted by Bass Mech View Post
its your evidence, you can decide to disclose if any or part of it exists depending on your situation, you can also remove the sound if you like.
I don't know about the US, but here in Canada, you are required to produce ALL documents and records in your possession or control if a case goes to litigation. If the other side believes you may be withholding certain key evidence (i.e. they somehow find out you have a camera), and if you do not produce any video evidence in your defense/prosecution of the case, then they may very well draw an adverse inference against you at best, or at worst, issue you an order for disclosure of video evidence.
Cameras are a double-edged sword in that respect. Best favour (Please forgive the Canadian spelling to my American friends!) you can do yourself is to be a good driver and stick to speed limits, Highway Traffic Act rules (and equivalent US legislation), and if something bad happens, you have no problem or fears of disclosing your video evidence.
I just ordered my Blackvue 2-Ch with Powermagic Pro and can't wait to use Bass Mech's install guide on my LS460. I'm guessing there are differences, but the ideas he presents are simple enough, and I have already removed my A-pillar once (which was very easy), so doing it again, along with the other trim pieces shouldn't be that difficult ... should it?
HumanMale is offline   Reply With Quote
Old 07-17-14, 04:36 PM   #77
vgsison
Very interesting read about the diy installation of the device. Thanks for sharing.
vgsison is offline   Reply With Quote
Old 01-05-15, 10:20 AM   #78
dnwin
Power Magic pro for IS250, driver side fuse box was limited.. I'm curious if anyone has a similar car. I installed it and it worked. I believe i must have put it in the wrong fuse because the battery is now drained. I set the setup to shut off at 23 volts. But It drained the battery dry.
dnwin is offline   Reply With Quote
Old 01-06-15, 08:47 PM   #79
dnwin
nobodee? any one with and 08 is250 install the pwoer magic pro? which fuses did you connect it with?
Old 03-31-15, 06:01 AM   #80
mingkwong
I have a DR750 installed few weeks ago, I found that the parking mode did not work for the most of the time i.e. when I shut down the car the cam will also shut down immediately. I have tried to set it cut off at 11.8v or 12v and work for 12 hours. It only works occasionally but for sure not as long as 12 hours. After the parking mode worked once for 1-2 hrs, it won't work again even after I run the car for 20-30km. but after normal use the car for few days, the parking code will work once again. Is it normal?
I don't tend to think this is the wire problem because it has ever worked. I just wonder if the battery of my car is not strong enough to support the parking mode?
Any one experienced a similar issue?
i agree with ^^^
but a few things to look for. if you mounted the front cam where i did, you probably cannot see the front cam from the drivers seat. so you need to verify if the front cam is on and the rear is off. if that is the case you may have a defective camera setup.
if both cams are off (much more likely) then either your time has expired or your battery voltage has fallen below the voltage threshold.
i have a 3 mile commute myself to work each day. and i can tell you that the battery will not hold enough charge to power the camera for a full 12 hours. you probably need to drive for at least an hour to get enough charge to cover the 12 hours or 8 if thats how its programmed.
mingkwong is offline   Reply With Quote
Old 03-31-15, 06:08 AM   #81
whoweedo
i should just pay you to wired mine up lol....too lazy. im in houston as well
whoweedo is offline   Reply With Quote
Old 04-02-15, 06:16 PM   #82
Bass Mech
it should be a similar process. i just installed the cameras and radar detector in my new cadillac CTS V sport twin turbo i traded my POS IS 350 in for.
except my fusebox is on the side of the dash and much easier to get access to.
Bass Mech is offline   Reply With Quote
Old 04-11-15, 10:56 PM   #83
y2kfrost
Awesome install. I decided to go with the BlackVue 650 and the cellink battery. Had it professionally installed since I did not have the heart to play with the Lexus wires. I did not have to use the MagicPro since I have a Relay installed in my car to prevent the Cellink from drawing power from the main battery when the vehicle is not running. All wires and battery pack was hidden in the driver side dash under the steering wheel.
Below are some pics that I took today when I picked up my car.
y2kfrost is offline   Reply With Quote
Old 04-13-15, 09:10 AM   #84
Answer
Thanks for the write-up! Just rewired my Itronic DashCam yesterday! Everything went smooth except the damn low-profile mini fuses... Since I used some Mini Add-a-fuse, I can't put the fuse box cover on... Oh well...
Answer is offline   Reply With Quote
Old 07-06-15, 07:04 AM   #85
Snowrydr01
subscribed for later use
Snowrydr01 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
1JZ/2JZ Oil Catch Can Questions 1JZPWRD Performance & Maintenance 54 03-07-17 02:47 PM
Window sticker.... Who has their original one still? 1JZPWRD SC- 1st Gen (1992-2000) 29 03-26-16 06:47 PM
Jay's 93 SC300 2JZGTE, Interior Redone by your's truly, 1JZPWRD !! 1JZPWRD Build Threads 392 06-12-15 06:18 PM
AL FS: 1992 Lexus SC400, 1JZ swap, Soarer R154, etc.... 1JZPWRD Lexus Vehicles Classifieds 18 07-29-13 06:11 PM
MM detail and tint hwy1isf IS F (2008-2014) 23 01-10-12 06:42 PM
Tags
2007, 2014, 600, blackvue, camera, ct200h, detector, front, hidden, install, lexus, location, radar, rear, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
