Low dust brake pads for Fsport?
Old 09-15-13, 08:23 AM
gs2isf
gs2isf's Avatar
Default Low dust brake pads for Fsport?
Does any company make low dust pads for the Rwd Fsport? The brake dust is just as bad as my Isf.....swapped those with Hawks. My front wheels look horrible after 30 miles to and from work. Will 2IS pads fit in the front? Rears are ok not much dust.
Old 09-15-13, 09:32 AM
dojoman
dojoman's Avatar
Non-fsport 3IS comes with low dust version I don't know the part number. I' hope Lexus will issue TSB for it.
Old 09-15-13, 09:42 AM
gs2isf
gs2isf's Avatar
Are they the same size for non af sport and F sports? I thought rwd models had larger brakes?
Old 09-15-13, 10:03 AM
Skinnyfats
Skinnyfats's Avatar
Just have to wait a little while until aftermarket companies to make them. You are looking for ceramic brake pads.
http://www.hawkperformance.com/performance/ceramic.php
Old 09-15-13, 10:08 AM
gs2isf
gs2isf's Avatar
Yes that's what I'm looking for. Do you know if pads from a 2IS fit the 3IS?
Old 09-15-13, 10:10 AM
Skinnyfats
Skinnyfats's Avatar
Not sure if the brakes are the same on both cars or not. Most likely going to have to contact the company directly or maybe someone here on the forums knows the answer.
Old 09-15-13, 10:37 AM
dojoman
dojoman's Avatar
Fsport and non fsport should be the same size only smaller size for 250.
Old 09-15-13, 08:06 PM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
To my knowledge the brake components between 2nd Gen and 3rd Gen are the same...
I switched to LOW dust pads when I had MY08 Sport Package IS350.. Totally worked like a charm and noticed no major differences on everyday street driving ...
I will double check the part numbers for you guys & gals tomorrow..
~ Joe Z
Old 09-15-13, 08:24 PM
gs2isf
gs2isf's Avatar
~ Joe Z
Thanks Joe your are a savior....I'm tired of washing my wheels every 3 days I can't stand seeing dust on them. I want a set of Vossens but now way I'm putting aftermarket wheels with all this brake dust it's insane....it seems worse than my Isf with the stock pads.
Old 09-15-13, 11:00 PM
IntegresS
IntegresS's Avatar
Yes please, low dust pads please!!! After one day of driving in stop and go traffic (round trip approx 50 miles), my front wheels look like this after spraying with water:
Old 09-16-13, 10:10 AM
dojoman
dojoman's Avatar
Will Lexus issue a tsb for it jut like they did for 2IS?
Old 09-16-13, 03:17 PM
Joe Z
Joe Z's Avatar
Lightbulb
Probably NOT as all F-Sports now come with "High Friction" pads....
So far from what I pulled up is that ALL the existing LOW DUST Front Brake Pads should be a direct fit to the 2014 IS250 / IS350...
I have several sets of parts numbers, but honestly without trying them out on my own, I cannot recommend to buy..
Last known LOW DUST pads I installed on my IS350 back in 09' was # 04465-30400 = Low Dust
Which shows to be superseded by # 04465-30450 = also Low Dust for IS350
IS250 Low Dust Front pad shows # 04465-53030 and maybe #04465-30480
That’s all I got for now... Double check before you buy or ask for "LOW DUST" pads
~ Joe Z
Old 09-16-13, 05:55 PM
dojoman
dojoman's Avatar
~ Joe Z
Thanks! Good info.
Old 09-16-13, 08:31 PM
dseag2
dseag2's Avatar
We have the same brake dust issue with the GS F Sport and to my knowledge Lexus hasn't issued a TSB for it. I wouldn't hold my breath. Best to research aftermarket brake pads.
Old 09-16-13, 09:11 PM
dojoman
dojoman's Avatar
How much would dealer charge to swap out to low dust?
Quick Reply: Low dust brake pads for Fsport?
