Radar detector install on 3IS?
Old 08-23-13, 08:23 PM
hnb
hnb's Avatar
Default Radar detector install on 3IS?
Has anyone hardwired a radar detector in their new 3IS? If so, did you use wiring from the rear view mirror area or just did you run a power cord directly from the fuse box? Pictures of installs would be great. Thanks.
Old 08-27-13, 01:53 PM
kanphoto
kanphoto's Avatar
I too would like to know!
Old 08-27-13, 09:48 PM
Stage3
Stage3's Avatar
A friend of mine just got her 3IS and wants to hardwire her V1. I've noticed that it hasn't been done or, at the very least, documented. Since this would be my fourth hardwire, I was thinking to just do it like I had done in the past: using the sunroof motor power supply. Since there really isn't too much info out there just yet, I'll have to see what's the best option. If the rear view mirror supply is easier to get to, I'll use that instead. Either way, I'll report back once I get it done which should be in the next few days!
Old 09-15-13, 07:09 PM
kanphoto
kanphoto's Avatar
bump... anyone?
Old 09-28-13, 09:20 PM
blubyu305
blubyu305's Avatar
Anyone try this yet? Just took delivery this evening and I'm appalled that I have to run the power cable into the arm rest just to power the radar detector.
Old 09-29-13, 06:51 AM
Vulaj
Vulaj's Avatar
I have a valentine one and run the power cord from the glove box to the passenger side up the front window by the passenger door and top of the window down to the rear view mirror.
Old 10-10-13, 10:36 AM
phil9892
phil9892's Avatar
I wired into the mirror. Just remove the mirror like the 2IS and the wire you need to plug into is BLUE=positive and WHITE=ground....did this on my gf's last night.
Old 10-10-13, 11:38 AM
vbx
vbx's Avatar
Is it possible to run a dash cam to the mirror wires?
I thought about running the wires down to the fuse but the IS350 has side air bags located on the pillars? and the wires would just get in the way.
Old 12-11-13, 06:16 PM
duckblue
duckblue's Avatar
It is best to doublecheck the power requirements of the dashcam. I think USB is usually 5volts whereas the car is typically 12v. Might need some sort of converter rather than just connecting the wires to the mirror power.
jcheng
RX - 4th Gen (2016-2022)
12-09-16 05:26 PM
Badasilva1
08-16-16 12:42 PM
treymoczy
01-07-16 07:37 PM
CLIS250
07-09-10 11:57 AM
cm09578
IS F (2008-2014)
25
12-14-08 01:22 PM
Quick Reply: Radar detector install on 3IS?
