Excessive brake dust
Old 01-29-14, 09:10 PM
  #46
amoney805
amoney805's Avatar
The brake dust is a PITA but it's worth it. They've saved me twice. Once when an old man swerved into my lane and when a there was a deer on the freeway driving 75.
Old 01-30-14, 06:38 AM
  #47
4TehNguyen
4TehNguyen's Avatar
i changed to a new set of low dust pads I had leftover from the 2IS while I was painting my calipers. Dont feel any difference in braking driving around on the street. Keeping the F Sport high dust ones in case I go to the track.
Old 01-30-14, 03:58 PM
  #48
r0shiro
r0shiro's Avatar
so the 2nd gen f-sport low dust pads will fit on the 3rd gen fsports? Font and Rear?
Old 01-30-14, 04:25 PM
  #49
dojoman
dojoman's Avatar
You may not need to change the rear. Fronts are the ones producing dust.
Old 01-30-14, 06:12 PM
  #50
crazych42
crazych42's Avatar
You just have to find a lower dust pad. There is always a compromise. You can get low dust and high performance, but with brake squeal. You can get high performance and no brake squeal, but dust. You can get low dust and low squeal, but reduced performance, etc.... I bought aftermarket pads for my TL's front brembos because of excessive brake dust and the aftermarket ones performed just as good as the stock pad, had little to no brake dust, but squealed for the first 20K miles... If my IS Fsports pad create a lot of dust they will be replaced pretty quickly.
Old 01-30-14, 08:10 PM
  #51
4TehNguyen
4TehNguyen's Avatar
350 front caliper is exactly the same as 2IS. Rear 3IS brakes are different than 2IS
Old 01-30-14, 08:23 PM
  #52
AndyL
AndyL's Avatar
To my knowledge and actual observation on non F Sport IS350, I find brake dust seems to be less when compared to my previous 06' IS350. It is more prominent on the front pads as the rear ones for both 2IS and 3IS are of the low dust type.
Old 08-06-14, 11:44 AM
  #53
v33k
v33k's Avatar
My Fix to the problem
Attached Thumbnails Excessive brake dust-20140802_135959.jpg   Excessive brake dust-20140802_144502.jpg
Old 08-09-14, 08:22 PM
  #54
DjRiDe
DjRiDe's Avatar
Any update on how these pads performed along with keeping away the brake dust?
Old 08-10-14, 12:57 AM
  #55
forum429
forum429's Avatar
I had those brake pads on my other car before (S60R Brembo).
They perform much like OEM pads.
Bite is good (Not excellent, but good) and not much dust.
Old 08-10-14, 05:30 AM
  #56
4TehNguyen
4TehNguyen's Avatar
after i swapped back to low dust OEM pads from the F Sport pads. I could tell the low dust ones have a mushier feel and noticeably less bite
Old 08-10-14, 10:34 AM
  #57
DjRiDe
DjRiDe's Avatar
Thanks for the info! My wheels are aftermarket and polished and after a wash within a day my wheels are black with these f sport brake pads. Trying to figure out whats the best solution because it looks really bad.
Old 08-10-14, 10:36 AM
  #58
4TehNguyen
4TehNguyen's Avatar
just swap in OEM low dust pads they are fine for everyday driving
Old 08-10-14, 10:50 AM
  #59
DjRiDe
DjRiDe's Avatar
Thanks bro! Time to go find the part # on sewell lol
Old 08-10-14, 11:04 AM
  #60
4TehNguyen
4TehNguyen's Avatar
http://is.sewellparts.com/accessorie...2006/1886.html
even though its for an 06 IS350, teh calipers are the same. I took my low dust pads from my 06 and put them in the 14
Quick Reply: Excessive brake dust
