Accuair
Old 06-22-15, 05:05 PM
Kwik8276
Kwik8276's Avatar
Default Accuair
Hey guys wanna know if anyone has any input on this , I just installed my accuair e level on my is250 fsport awd , the car looks great but the front does not go as low as it should , the back sits great , just the front that's bothersome !! I'm sitting on vossens 20x9 +38 and 20x10 +45 in the rear !! I don't think the wheels are the problem , any help would be greatly appreciated
Old 06-22-15, 05:06 PM
Kwik8276
Kwik8276's Avatar
Here it is with it aired out
Old 06-22-15, 05:46 PM
VMRWheels
Former Sponsor
VMRWheels's Avatar
Hmmm, it's possible you're restricted by the sway bar endlinks? Same issue I had when I was first dropped on AirREX. Picked up some adjustable endlinks and problem solved
Old 06-22-15, 07:15 PM
Kwik8276
Kwik8276's Avatar
Default Accuair
Where can I pick them up ? And is yours awd as well ??
Old 06-22-15, 09:27 PM
Reeladdict
Reeladdict's Avatar
hey did you get the right struts for AWD? Not sure what the difference is, but I know they have different ones for AWD and RWD.
Old 06-23-15, 06:04 AM
Kwik8276
Kwik8276's Avatar
Default Accuair
It's the factory struts I'm using so yeah they're the right ones
Old 06-23-15, 08:00 AM
specONE
specONE's Avatar
do you have pictures of front suspension setup?
Old 06-23-15, 09:03 AM
osh3is350f
osh3is350f's Avatar
I'm on air runners and accuair elevel. The shop that did my set up had to put spacers on my fronts to get necessary clearance. But I have a RWD and currently on my stocks. I would just check to make sure your not hitting any bolts
Old 06-23-15, 01:28 PM
Kwik8276
Kwik8276's Avatar
Default Accuair
Yeah I heard the rwd are a lot different than the awd and don't think the spacers will help
Old 06-24-15, 12:46 PM
Tai3IS
Tai3IS's Avatar
If yours is an AWD model, you might want to check and see if the front driveshafts are hitting the subframe. It's a completely different car, but i helped install the air ride on my friend's VW CC and in order to get the car to lay down, we had to notch the sub frame for the driveshaft to clear. But like i said, that's a completely different car. Not sure what the AWD setup looks like on the 3IS. Mines a RWD.
Old 06-24-15, 08:34 PM
Kwik8276
Kwik8276's Avatar
Default Accuair
How is that done if u don't mind me asking ?
Old 06-24-15, 09:38 PM
specONE
specONE's Avatar
air the car down and use a flash light to try to see what is making it now go down any further?
you probably should've went accuair management only and Airrex AWD application strut/bag setup. you would've got low for sure with that.
Ozzy
06-12-20 06:34 AM
Phresh2010
06-26-17 08:19 AM
1000hp
03-14-14 01:36 PM
Damaster32
02-09-09 03:17 PM
love67
Suspension and Brakes
08-07-08 08:42 PM
Quick Reply: Accuair
