View Poll Results: OCTANE - Which gas do you put in your 3IS
I always use 91 or higher.
259
91.20%
I sometimes use 89 or 87.
1.06%
I always use 89.
2.11%
I always use 87.
16
5.63%
Voters: 284. You may not vote on this poll
OCTANE - Which gas do you put in your 3IS and why?(merged threads)
Old 10-13-13, 02:59 AM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Question OCTANE - Which gas do you put in your 3IS and why?(merged threads)
Poll question at top.
The recommended minimum octane for the 3IS 250 and 350 engines is 91. For comments, consider:
- Have you tried a lower octane?
- Any differences noted in engine sound, fuel economy, or performance?
- Any concerns with reliability?
- Is fuel cost savings important to you?
Old 10-13-13, 04:24 AM
CtSFox
CtSFox's Avatar
I will use 91 when when I my 3IS comes in. Among other reasons, higher octane gas often has better/more detergents which is important to prevent carbon build up in direct injection engines.
Old 10-13-13, 06:56 AM
jhs82
jhs82's Avatar
91 octane in US is the same as 95 octane in Europe (different ways to rate the fuel).
95 octane RON is the lowest petrol quality you can get i Sweden.
EDIT: And all petrol in Sweden has 5% Ethanol mixed in to it.
Old 10-13-13, 07:08 AM
Stitch626
Stitch626's Avatar
Car requires premium so thats what i put
Old 10-13-13, 07:51 AM
keyframe13
keyframe13's Avatar
All the gas in US has "up to 10% ethanol" but i saw in the news they caught gas stations having 40-50% ethanol in it. Imagine what that does to your engine.
Old 10-13-13, 07:59 AM
ddb
ddb's Avatar
WARNING: do not put anything lower than 91 octane gas (US specs) in your 3IS and also the 2IS as well.
Both engines (250 & 350) have been designed to operate on that specific gas and the ECU will not adapt to lower octane like other engines that accept different octane.
If you have no option when filling up to put lower octane, only fill up about 1/4 of the tank and find another gas station and fill up the rest with 91.
Many people think this is all BS and that they can put anything they like. WRONG. The timing on the engine has been designed for the slower burning the 91 octane gas has. It allows to burn it all and use maximum energy from it.
Using lower octane will result on waste of energy, carbon build up on the valves, and knocking on the lifters (that is a VERY BAD THING). You will lose power which will make you hit the gas pedal harder resulting on extra $$$ out of your pocket (besides having to fix the engine on the long run).
Use ONLY 91 octane gas.
Wayward67 (08-31-22)
Old 10-13-13, 09:42 AM
aTeAse
aTeAse's Avatar
Should I completely drain the car on first fill up ?
Old 10-13-13, 10:30 AM
Hoovey689
Hoovey689's Avatar
Use 91 Octane. The higest grade possible is needed due to our engines direct injection and high engine compression ratio. Now unlike older vehicles, you can put a lower grade octane into these vehicles because the ecu is smart enough to adjust for knocking and pinging. So once in a jam or emergency is fine, but prolonged use will affect both engine perfomance and fuel economy.
Old 10-13-13, 11:00 AM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Exclamation
For those of you putting in anything less than 91... I'm just going to flat out say drink less Starbucks
But seriously lease or not.. Use the correct premium gas.
It comes out to $3 a tank between 87 & 91, if the difference is .20 cents.
Joe Z
Old 10-13-13, 11:23 AM
eyeball
eyeball's Avatar
Originally Posted by Joe Z
. It comes out to $3 a tank between 87 & 91, if the difference is .20 cents. Joe Z
Precisely. If you do the math, $3 is nominal to me
Old 10-13-13, 01:47 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
^^^when I travel to the US, I put the higher octane gas because it's so cheap. In Canada it's 12-15 cents more per liter. On a 60 L (~16 US Gallons) fill-up, the dollars become more apparent @ 8 to 9$ more per tank.
I've filled 91 three times, once 94, and my current tank at 89. I noticed a slight improvement in power and response going to 94, and a bigger difference dropping down in power going to 89. The car today feels less responsive as though I have 5 passengers in the car.
Moving forward, it will be 91 most fill-ups and when I have the bigger urge for more power, 94. Too bad 94 costs 20 cents more per liter!!! I wonder if those octane boosters added to my 89 tank will work to bring it up a few points...
Old 10-13-13, 02:51 PM
RaysurX
RaysurX's Avatar
The manufacturer has clearly stated to use PREMIUM GAS. 91 or higher for those here in the US. They (Toyota / Lexus) do not have any vested interest to make us buy more expensive gas. It's purely based upon the engineered needs of the engine design.
(Getting on soap box and not directing this at the OP)
We all just bought $35k+ cars so don't "nickel and dime" your gas at the risk of ruining the main component of your ride and as one poster noted, if you want to save a couple of bucks on something.. cut down on the Starbucks.
igetit14is (12-03-18)
Old 10-13-13, 06:10 PM
doctorttt
doctorttt's Avatar
Simple answer: I bought it with cash, and I'm going to put the highest quality of gas in it.
Old 10-13-13, 07:53 PM
yowps3
yowps3's Avatar
Exactly! Only idiots pay so much cash for their nice car and try saving a few bucks by feeding it crap
Old 10-13-13, 08:30 PM
vbx
vbx's Avatar
I think one of the excuse I've heard was they're leasing the car so who cares.
But whats the point of getting the 350 to put cheap gas and get it to run like a 250.
Quick Reply: OCTANE - Which gas do you put in your 3IS and why?(merged threads)
