Rear vent on center console!!!
Old 08-22-13, 12:19 PM
Therealman
Therealman's Avatar
Default Rear vent on center console!!!
I have notice that not much air or no air at all comes from the vent thought is this the case for all IS?
I have a 3IS 350 f sport
Old 08-22-13, 12:36 PM
offroad200
offroad200's Avatar
You should have an S-Flow setting. In a nav car you go to "Climate", then the three little dots "..." on the bottom right hand corner of the screen. That will pull up options. Select the last option. This will create more air flow for the rear. You can change it case of a single occupant, S-flow directs most of the air to the driver. I really don't know how to explain the pictogram though. Haha.
Old 08-23-13, 01:01 AM
jagged
jagged's Avatar
I was initially wondering how to make air come out from the rear aircon vents and tried to find the setting in the infotainment screen.
As there's no manual sliding switch at the rear vent area, I realize that the solution is quite simple. Air will come out as long as you don't push the vents all the way to the left or right.
atc789
05-20-14 08:35 PM
Gx470Rx300
RX - 1st Gen (1999-2003)
11-12-10 05:08 PM
uae
09-13-07 01:14 PM
SteveH
01-09-04 07:13 PM
marketbully
04-08-01 04:21 PM
Quick Reply: Rear vent on center console!!!
