Warm air from outside
Old 04-05-14, 10:05 PM
CharlieVo
CharlieVo's Avatar
Default Warm air from outside
I have a 2014 Lexus IS350 Fsport. When i press the button outside air mode and no fans are on. I get warm/hot air even when the outside temp is cold. Anyone have this issue ?
Old 04-05-14, 10:37 PM
Aeromotive
Aeromotive's Avatar
Could this have to do with your climate control set temperature?
Old 04-05-14, 11:33 PM
UncleSpud
UncleSpud's Avatar
I noticed the same thing before I drove the car off the dealer's lot. I had a technician check it and was told it was normal. Although this wasn't a satisfying explanation, it hasn't really been problematic, and I've barely been aware of it since.
Old 04-06-14, 01:38 AM
TheShaddix
TheShaddix's Avatar
set your temp to the lowest setting while the fans are on, then turn the fan off.
Old 04-06-14, 02:12 AM
aTeAse
aTeAse's Avatar
I hate that we have to turn the fan on to adjust the temperature.
Old 04-06-14, 05:02 AM
Alius
Alius's Avatar
Yep, this is normal for our cars apparently, have to turn the fan on to adjust the temps then turn it back off, a little annoying but nothing crazy.
Old 04-06-14, 08:50 AM
markb3
markb3's Avatar
I noticed this too. For example, its been very cold so my settings are on hi for temperatures. Next day it is randomly warm so when I get into the car, I turn off the heating altogether. After a while, I'm sitting and starting to get really warm, put my fingers up to the vents and the hot air is coming out. So I figured this out too, turn it on, lower the temp, then turn it off.
My only question is.. isn't there a way to just turn it off completely? Shouldn't "off" mean off? If I wanted air to come out from the vent, isn't that the point of using the lowest fan setting instead?
Again, as the guy mentioned above, annoying, but nothing crazy. Just wondering myself as well.
Old 04-06-14, 09:12 AM
Alius
Alius's Avatar
I just press the air to recycle within the car and nothing comes out of the vents even in the OFF position, but yea I know what you mean, I too wish we can just turn it off completely.
Old 04-06-14, 11:17 PM
CharlieVo
CharlieVo's Avatar
Okie i'm going to turn the temp all the way down with the fan on and than turn the fan off and see. Thanks everyone and will report back.
Old 04-07-14, 06:26 AM
FSPORTJC
FSPORTJC's Avatar
I always tilt the sunroof upwards while driving with he fan off it blows the outside air into my face at a higher speed than with the sunroof not tilted up.. try it you will see it makes a huge difference!
Old 04-07-14, 01:40 PM
fast350
fast350's Avatar
The explanation is that when you're going down the highway and you have the a/c set to fresh air the force of the air coming off the hood will go through your a/c system at whatever the temp was set to. The only problem with that is the compressor isn't on so if the blend door is even slightly open to the heater core side it will go through there as well and warm up the air. Set your temp to low or just put it on recirc when you have the air off.
AKA5
RC F (2015-present)
10-30-15 12:13 PM
Twisties88
02-03-14 10:39 PM
mattham912
IS - 1st Gen (2001-2005)
03-30-09 07:46 PM
VanIS350
08-30-06 12:01 PM
Mykotse
05-07-04 05:59 AM
Quick Reply: Warm air from outside
