Aftermarket radio stock sub question?
Old 03-21-17, 11:41 PM
roshedomv2
roshedomv2's Avatar
Default Aftermarket radio stock sub question?
For anybody that has replaced their radio with an aftermarket radio using the beatsonic or scosche dash kit, were you able to keep your factory subwoofer working with then new system? I installed a radio via the scosche kit, but the factory subwoofer is not working.
Old 08-29-17, 09:47 PM
Macklock
Macklock's Avatar
I have the kit installed. And to answer your question no, I haven't found a way to get the sub in the rear working. Every other speaker seem to be working fine though. Maybe someone here can shed an insight as to why.
Old 09-01-17, 10:02 PM
Arrta
Arrta's Avatar
You could try this AX-ADTY01 (google it), or read the manual and see if you can adapt the install instructions to turn on the amp.. Sounds like its not getting power.
cl147
04-22-18 02:54 PM
ShiftyD2k
04-06-15 02:23 PM
DangWhat
07-02-09 09:41 PM
phil villa
06-26-03 05:34 AM
Quick Reply: Aftermarket radio stock sub question?
