Acura TL Type-S or IS350?
Old 02-12-17, 09:18 AM
  #31
carlos3366
carlos3366's Avatar
Default timing belt and front wheel drive?
go for the IS350 but make sure it doesn't have the airbag recall problem.
I shift the heck out of my 250 to make it go fast, so far no tranny problems with 144,000 miles.
Old 02-12-17, 11:46 AM
  #32
Ling2IS
Ling2IS's Avatar
I've been asking my local service advisor about the airbag and door panel recalls, no luck. I'm sure if a 350 had that problem, it would be covered under the recall, in time.
Old 02-15-17, 11:21 AM
  #33
Ling2IS
Ling2IS's Avatar
Update - I test drove a TL-S a few days ago and my general impressions are..
  • Butt dyno wise, IS350 is noticeably quicker
  • IS interior feels more premium and less dated
  • TL-S steering feels heavier, slightly more direct
  • TL-S backup camera quality is garbage
Overall, I am definitely leaning towards a 350. The only thing going for the TL-S at this point is the exterior looks.
Old 02-15-17, 11:52 AM
  #34
Rezno
Rezno's Avatar
Yeah the FWD layout and the very very long gears limit it in acceleration. It would be much faster with Honda's 9 speed auto or 8 speed dual clutch. Where did you drive it? Have you taken it to a back road?
Also I think the backup camera being terrible is something on all Hondas from 07 - 09. They fog up and get dirty too easily and the resolution is far far from perfect.
Old 02-15-17, 11:57 AM
  #35
Zmon
Zmon's Avatar
In regards to the steering, you can swap out the steering ECU for one off an IS-F (08-14), most people seem to have 11-12 units. Makes it heavier, direct, more feedback.... you can stiffen it up even more by hitting the pwr switch. I can't explain it and I've had mine for a month now, but IMO, huge improvement over my 08's stock steering ECU.
Old 02-15-17, 12:03 PM
  #36
Ling2IS
Ling2IS's Avatar
Hm, I've seen a thread or two about that. How much does the ISF steering ECU run? How easy is it to install?
Old 02-15-17, 12:04 PM
  #37
Ling2IS
Ling2IS's Avatar
I had limited seat time, so I drove it on a wide ish street and some quiet residential areas. There were no back roads nearby haha
Old 02-15-17, 12:28 PM
  #38
Zmon
Zmon's Avatar
It's not hard to install. Take out the battery, remove the cover underneath it and there's the ECU. Just unclip the connectors and itll pull right out.
Cost wise, it varies depending on which years you buy. 08-10 are the cheapest (and the heaviest feeling iirc. Someone here on CL was selling an 08 for $200 iirc), 11-12 models seem to be more common here, I personally paid $350 for mine, then you have 13-14s which cost the most, not really any direct comparisons between the 11-12 and 13-14 units so its safe to say the 11-12 may be a better choice.
Old 02-15-17, 12:33 PM
  #39
Ling2IS
Ling2IS's Avatar
Do you ship your ECU out to get it coded or you're paying for a new ECU with the steering ECU already inside?
Mhm, I see. I've taken out the stock ECU before
Old 02-15-17, 01:08 PM
  #40
redspencer
OG Member
redspencer's Avatar
You're paying for a new (or used) IS-F Steering ECU (either the 08-10, 11-12, or 13-14 version) and after installing the unit, you'll need to get it calibrated at the dealership via TechStream.
Old 02-15-17, 01:10 PM
  #41
Ling2IS
Ling2IS's Avatar
Oh gotcha. I don't intend to drive the car super hard, maybe a back road here and there, so I'll see how I like the handling after just coilovers and maybe sway bars.
KangstaxD
08-04-09 07:50 PM
Lama
01-01-08 10:22 PM
inxexisten
IS F (2008-2014)
16
10-29-07 07:40 PM
omd316
Drag Strip
29
10-23-07 12:41 PM
shoei
05-26-06 10:02 AM
Quick Reply: Acura TL Type-S or IS350?
