08 IS250 - Intermittent No Sound From Radio
Old 01-23-17, 03:12 PM
APynckel
APynckel's Avatar
Default 08 IS250 - Intermittent No Sound From Radio
So, intermittently, I'll get some days where I can get sound no problem from my radio / control beeps from my speakers. Other days, nothing. The radio turns on and shows me that everything is working, just no sound. I've read that this has to do with moisture in the amplifier. Can anyone confirm this? Any workaround to get it to function properly again?
Thanks
Old 01-24-17, 06:53 PM
Gville350
Gville350's Avatar
You mentioned exactly what I was about to suggest. Looking for moisture around the amp area in the trunk. Remove all connections from the amp and remove the amp from the trunk. Any moisture or rust from a build-up of moisture present on the amp itself OR in the area where the amp sits?
Old 01-24-17, 07:14 PM
APynckel
APynckel's Avatar
I pulled the trunk trim piece above the amp to look at it, felt around it and didn't feel any blatantly obvious wet or see any. I need to pull it and examine the guts for condensation / corrosion...
I have noticed better reliability from the amp since I pulled the trim piece though, thinking the amp has better ability to breathe now.
3dolphin
10-23-17 07:13 PM
LEXis300hp
08-10-17 05:01 PM
GregZ1969
06-08-14 09:16 PM
Lexicon1
02-14-09 08:36 PM
LEXBUBL96
09-02-06 09:21 PM
Quick Reply: 08 IS250 - Intermittent No Sound From Radio
