What do these code mean?
Old 01-11-17, 05:19 PM
is250pr
is250pr's Avatar
Default What do these code mean?
I own a 2006 Lexus is250 awd,
i was driving back home and the Check engine light went on and also it said check vsc i took it to autozone to scan it and all these codes popped up.
i also noticed that ever since the Check VSC came on my traction wont work.
Attached Thumbnails What do these code mean?-91e851bb-1712-462b-b01a-46bc7e0b4108.jpg
Old 01-11-17, 05:27 PM
Zmon
Zmon's Avatar
The misfire codes makes it sound like the carbon build up problem. The catalyst codes may be due to the carbon build up, or, considering you live in Minnesota, and if you drive in the winters, you may just have a hole somewhere in the exhaust caused by the salt and rust.
Old 01-11-17, 05:30 PM
is250pr
is250pr's Avatar
A couple months ago my y pipe did have holes, i had them weld and the car has been quite ever since.
Old 01-12-17, 07:24 AM
Bichon
Super Moderator
Bichon's Avatar
If they just welded over the holes and didn't cut out and replace the corroded pipe, your earlier fix may have failed. It would definitely be the first place that I would look.
Jbakyy
12-13-22 10:35 PM
SynicalVip
170
01-03-19 08:06 PM
Joppa013
10-27-17 12:44 PM
billymowat
11-06-13 05:39 PM
dci4life
08-20-12 11:55 AM
Quick Reply: What do these code mean?
