Changed out my transmission fluid
#77
Got my '06 IS350 at 109k miles. Currently has 145k miles on it. Been on the fence about replacing my tranny fluid. No tranny issues whatsover. Want to keep the car for as long as I can but would not want to tranny to go out on me sooner than I would hope. Dealer says don't change it. But most on this post obviously has attempted and gotten good results. Question is, now that the original fluid's been replaced, how often will you now need to replace the fluid?
#79
Tech Info Resource
Tech Info Resource
I am not sure that analysis is worth the electrons it takes to display the results. I doubt they've ever seen another Aisin like yours ever, so they can't comment on what is elevated or not with any accuracy. As with all UOA, the meat is in the trending and the knowledge of the person analyzing the results. Neither are present with this single point perspective, so I'd personally take it with a big grain of salt if I were you.
#83
Thanks for looking at things with a different perspective Lance. I think I might be the first person on the CL forums to provide a sample of used transmission fluid from an Aisin A760E unit to Blackstone Labs for analysis so it is probable that the results are from a single point analysis. The transmission still behaves like it's supposed to so all is well.
Looks like we need a few other volunteers that have recently been doing trickle flushes on their A760E transmissions to provide some samples to Blackstone so we can start building a larger database.
#87
This DIY video will help anyone doing transmission fluid change. If you change the fluid on cold engine/transmission, you can skip the part of shorting terminals at OBD port.
#88
ChrisFix explains everything in this video.
#89
The IS has a a sealed Tranny case. Sort of. As I found out, the Miata uses the same tranny.
#90
I have drained and filled my Miata as I am doing with my IS350 now.
