2008 IS250 idle rattle with unstable rpm(Misfire?)
I just recorded this video of my car's engine acting weird when idling in gear. The rpm is already low and the car vibrates during stops. When I tried turning on the A/C, the rpm just jumps and jumps and jumps! I also heard something from the engine clicking as the rpm jumps. Please tell me if this is the engine misfire that is caused by the carbon buildup? I'm scheduled to take my car in for the test next Tuesday, just want more advice from the club if possible.
Here is the link to the video I shot:
Thanks!!!
Eric
Thanks!!!
Eric
For now, I just hope it will be the carbon buildup so it will be covered by my extended warranty that is running out at the end of this year.
I think any car could have carbon build up issue, it's just a matter of its extent. IS 250 is just prone to it due to its design I think.
When IS250 breaks down by carbon your 250 should pops up a CHECK ENGINE car shake bad and stall misfire everyEngine code should be stored in your ECU, if you check my other post about Mark Levinson Audio system why it's not loud and no BASS, i coincidentally got it fixed by REPLACED a new Lexus battery, i just got this car about 10 days, the dealer had a dead battery on my car, replaced new one everything worked perfect. i love Mark Levinson Audio system !
I saw your posts here and there on Youtube also, there is a way to reduce or even prevent Carbon buildup for IS250 but no one believes it !
True, any car could get carbon buildup but non direct injection engine gets clean up by itself with the fuel injector overhead valve stem spray as well as IS350 the 350 has enough Horsepower to get a very least least of carbon and the IS250 DON"T, your IS250 doesn't look like it has the carbon problem, idled fine when YOU DID NOT TURN ON YOUR AC or HEAT, the RPM jumps like that because of you have a weak battery or alternator, i'm trying to help you Huang.
how do you take out the ducts? Are there just like clips (top and bottom of the duct?) you squeeze from the inside and it pops outward? It seems like my hand aren’t strong enough or I’m doing it wrong…
viettho
10-01-07 01:55 PM
