Will a 2008 transmission fit a 2006 lexus is350? Reply quick please
Old 10-12-16, 09:03 PM
JasonTP350
JasonTP350's Avatar
Default Will a 2008 transmission fit a 2006 lexus is350? Reply quick please
Title says it all, get back to me asap please.
Old 10-12-16, 09:48 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Assuming you mean a 2008 IS350 transmission into a 2006 IS350, then the answer is yes.
Jeff
Old 10-12-16, 09:49 PM
JasonTP350
JasonTP350's Avatar
Jeff
Yeah I'm talking about putting a 2008 6AT Transmission into a 2006 Lexus IS350
Old 10-12-16, 11:36 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
There are 3 types of 6AT used in a 2008 IS, the A960E (IS250 RWD), A760E (IS350 RWD) and A760F (IS250 AWD). As I said, as long as you get an A760E from an IS350 RWD, you should be good to go.
Jeff
Old 10-12-16, 11:38 PM
JasonTP350
JasonTP350's Avatar
Jeff
okay thank you very much
Old 10-13-16, 04:43 AM
lysis250
lysis250's Avatar
If your IS was made after 10/05 yes it will however if your IS was made before that it won't. I was in the same boat as you a few months back.
Old 10-13-16, 04:53 AM
HankMoody
HankMoody's Avatar
Can you explain more ? What were the reasons that it wouldn't work ?
Old 10-13-16, 06:41 AM
istundra
istundra's Avatar
Check your VIN plate on the driver side door jam! it will have the Transmission model #! Look for A760E
Old 10-13-16, 07:13 AM
JasonTP350
JasonTP350's Avatar
Mine is made through 9/05 why wouldn't it work?
Old 10-13-16, 08:23 AM
lysis250
lysis250's Avatar
Something to do with the torque converter being different, I spoke to some people they say if you put the old torque converter in the newer transmission it should work.
Old 10-13-16, 05:33 PM
Gville350
Gville350's Avatar
Just make sure to purchase a used trans WITH a matching converter.
Old 10-13-16, 09:55 PM
MWIS350
MWIS350's Avatar
2006-2013 IS350 transmission RWD should be the same.
scchreiber (12-17-21)
Old 12-28-18, 04:15 AM
Alowe2377
Alowe2377's Avatar
Default My question was will a 2006 is 350 match a 2007 es 350 transmission
Jeff
Old 12-28-18, 12:21 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
No, it won't.
Jeff
dzyj
06-28-15 03:46 PM
skyofx
05-06-12 07:07 PM
desco5
02-22-12 07:18 AM
jaredc
04-29-08 10:32 AM
Quick Reply: Will a 2008 transmission fit a 2006 lexus is350? Reply quick please
