Whats the name of this part and where does it go connected?
4th Gear
Hi guys I m new over here and I bought a very used Lexusis250 2006 and I was wondering if someone here would be kind enough to help with this part attached in the pic,I wanna know its name and where can I connect it?
The part is right in the center of the pic
Thanks
Thanks
Vapor Canister Purge Valve/Solenoid
This part is called a Vapor Canister Purge Valve/Solenoid. It controls the vapor from your gas tank and circulates it through your intake manifold back to be burned.
You can find it here for 57.79.
http://www.rockauto.com/en/catalog/l...+solenoid,4936
Let me know if this is the part you were referring to?
It is connected under the main engine cover to the side of the Intake. Two hoses and one electrical clip with a bolt holding it in place. You can install this in about 2 minutes.
