'06 IS250 amplifier circuit board diagram?
Old 08-16-16, 12:22 PM
06dblexus
06dblexus's Avatar
Default '06 IS250 amplifier circuit board diagram?
Lexus told me today that my amp went bad that one of the channels is bad, i can resolder that stuff at work, where could i find a diagram of the circuit board so i know where it is?
Old 08-16-16, 02:29 PM
arakris
arakris's Avatar
Keen to get a circuit board diagram as well. I seem to have a faulty channel as well.
Old 08-16-16, 02:37 PM
06dblexus
06dblexus's Avatar
Theres gotta be one somewhere, i just picked up my car from dealer its 492$ for one with installation or 342.45$ with out install, need the diagram so i can find it an replace it myself lol
Old 02-20-17, 05:17 PM
warrionex
warrionex's Avatar
Default Amplifier pics IS250/350/ISF 2006-2010 Pioneer 86280-53110
Old 02-20-17, 06:59 PM
arakris
arakris's Avatar
+1
I had the same problem! I had to use the Amp with one channel (front) disconnected for about 2 months before I found a second hand replacement. Managed to score a bargain and get it for $50 from a wreckers! I still have my old Amp so if anyone figures out how to fix a broken channel please let us know.
Old 03-26-24, 12:23 PM
Jeremy27
5th Gear
Jeremy27's Avatar
Default Probleme ampli is 250 2006
Originally Posted by arakris
+1
bonjour je me presente jeremy 35 ans je voulais savoir si vous aviez trouver le schema car mon ampli est en panne.le son fonctionne en mettant le contact maos moteur demarrer plus rien.jai bien 14v a l'arriver a l'ampli.les fusible sont bon
Old 03-26-24, 04:57 PM
2013FSport
2013FSport's Avatar
Received 1,484 Likes on 1,238 Posts
French to English
Hello, my name is Jeremy, 35 years old, I wanted to know if you had found the diagram because my amp is broken.the sound works by putting the MAOS motor ignition, start nothing.I have 14V to get to the amp.The fuses are good.
As of this writing, I don't think anyone has. The original thread, with a single bad channel shouldn't be to hard to troubleshoot though!
If yours doesn't work at all, these are known to get water damage from the trunk vent failing. Look on the rightside in the trunk under that plastic tray for water damage. Aka traces of rust.
Old 03-26-24, 10:51 PM
Jeremy27
5th Gear
Jeremy27's Avatar
j'ai regarder si il y avait de la rouille et il n'y a rien et vu qu'il fonctionne avec le contact je me dit qu'il a surement un probleme sur le circuit au plus apres contact .car la tension est bonne a l'entree.
Old 04-01-24, 04:10 PM
Yodog
Yodog's Avatar
Probably a cold solder joint. I would touch up all the capacitor joints just for good measure.
Old 04-01-24, 05:39 PM
2013FSport
2013FSport's Avatar
Look for bulging leaking capacitors too. IC's with blisters, bubbles, melting. Obviously check the left right balance and make sure no one jacked with input settings.
Old 04-01-24, 10:26 PM
Jeremy27
5th Gear
Jeremy27's Avatar
j'ai voulu essayer de tester le circuit mais personne n'a le schema c'est un peu embetant.mais je vais essayer de refaire les soudure . Je redemonte l'ampli cet apres midi je vous mettrais des photos
Old 04-02-24, 09:12 AM
2013FSport
2013FSport's Avatar
And maybe be so kind as to translate to English going forward?
You have any test equipment like an oscilloscope?
Old 04-06-24, 05:34 AM
ELexis
ELexis's Avatar
Might the following provide additional information;;
Lexus ES200, ES250, ES260, ES300h, ES350 (2018-
p/n 86280-33310 or 86280-53110 ?2022) premium amplifier pinout
https://pinoutguide.com/Car-Stereo-T...E_pinout.shtml
Old 04-06-24, 03:56 PM
Jeremy27
5th Gear
Jeremy27's Avatar
Thank you. I quickly reassembled and cleaned it but still there is a sound when I turn on the ignition but after that nothing more. Sometimes when I am driving it comes on for 2 seconds and then turns off
aCortIS101
08-11-11 11:58 AM
nnnnny
Canada
05-05-10 10:51 AM
SteveTango
01-24-10 07:44 PM
Quick Reply: '06 IS250 amplifier circuit board diagram?
