DRL/ hi beam fuse
Old 08-05-16, 04:40 PM
SeanO
SeanO's Avatar
Default DRL/ hi beam fuse
Anyone know which fuse to pull if i want to disable my drl / hi beam bulb?
Old 08-05-16, 06:38 PM
top5
top5's Avatar
There is no fuse. Canadian models cannot have their drls disabled
Old 08-05-16, 06:58 PM
SeanO
SeanO's Avatar
So my only option would be to unplug the bulb then?
Old 08-05-16, 07:59 PM
flowrider
flowrider's Avatar
Received 1,826 Likes on 1,288 Posts
Has be a fuse, otherwise a malfunction would cause a fire rather than a blown fuse. Anyway I have a USA 2008 ISF model and just looked in my owners manual. It says there are two types of underhood fuse boxes, (type A) on right side of car (standing in front and facing toward the windshield, and (type B) on the right side. The manual says that in the Type A box it is fuse No. 8, a 10 amp fuse. However this fuse also controls a number of other things among them Fog Lights, power windows and etc. In the type B box it is a 15 amp fuse in location 19 and only controls "Headlight Beams".
Hope this helps you.
Lou
Old 08-05-16, 11:13 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
What you're looking for if you want the fuse is the one labelled H-LP UPR, it will either be 15A or 20A and is plugged into the Front Controller inside the fuse box behind the LH headlight.
Jeff
Old 08-06-16, 07:43 AM
SeanO
SeanO's Avatar
Perfect - Thanks Jeff
I looked in my manual and was wondering if it was the one
pentiumvi
RX - 4th Gen (2016-2022)
38
01-16-24 05:33 PM
1SLOGS
04-17-15 06:47 PM
ReyRey305
08-08-14 09:36 PM
redholm
RX - 1st Gen (1999-2003)
11-25-12 01:35 PM
g356gear
IS F (2008-2014)
10-10-12 04:18 PM
Quick Reply: DRL/ hi beam fuse
