150k miles valve cover gasket changed
Old 08-09-16, 01:13 PM
Gville350
Gville350's Avatar
Check your lug nuts AND tires for debris.
Old 08-09-16, 03:26 PM
Deathrow23
Deathrow23's Avatar
I feel the vibration when it's idle and not moving
Old 08-10-16, 05:57 PM
Gville350
Gville350's Avatar
Oh, well that's no good at all!
Old 08-11-16, 05:17 PM
Deathrow23
Deathrow23's Avatar
Ah.....just realized I also changed serpentine belt to a new one. Obviously tighter than what was replaced, maybe that explains it.
Old 08-12-16, 10:23 AM
Gville350
Gville350's Avatar
The correct-length OEM belt shouldn't introduce ANY vibrations into an idling car. Something else is at fault here; I'd start by getting those gaskets/seals checked out.
Old 08-13-16, 07:19 PM
Deathrow23
Deathrow23's Avatar
So reopened the valve cover again today and all gaskets were still in there. Replaced them with new ones. This time is took about a third of the original time.
Old 08-14-16, 03:59 PM
Gville350
Gville350's Avatar
Well that;s good to hear; but did you still have the vibration at idle? Is it felt in the steering wheel, brake pedal, accelerator, or in the seat through the chassis?
Old 08-14-16, 04:48 PM
Deathrow23
Deathrow23's Avatar
Just a subtle shake felt through steering wheel. But also, when it happens with the Ac on, when I turn off the Ac, it stops.
Old 08-15-16, 04:30 PM
Gville350
Gville350's Avatar
Maybe adding one of those steering dampers might help you out here.
Old 06-25-18, 02:52 PM
noblesenga
noblesenga's Avatar
Originally Posted by Deathrow23
when I did my last oil change, there was oil on my spark plugs, mostly the rear plugs closest to firewall. Plus I'm losing oil somewhere, before 7k miles after a oil change, my oil would be pretty low, even one time prompting the low oil light. Also with age, 150k miles and including oil on plus and losing/burning oil. I thought it was time to change them as I am deciding to keep the car for as long as I can.
Sorry, I didn't take pics of the steps. But can offer help if anyone decides to do it.
Hey man. I think I need to do the same procedure as one of my spark plug seem to be leaking. Could you please check out my post and tell me what you think? >> https://www.clublexus.com/forums/is-...-with-oil.html
Old 10-14-19, 07:32 AM
Gustavo621
Gustavo621's Avatar
I've driven it about 150miles already. Doesn't seem like anything is different.
Nope, just did it on the fly
sorry to bring an old thread back to life. Was there anything that needed to be reprogrammed after this? Or just straight forward remove valve covers replace gaskets and reinstall valve covers? This doesn’t mess with the timing at all does it?
Old 10-14-19, 07:34 AM
Zmon
Zmon's Avatar
No, that's all you need to do.
Old 10-15-19, 05:28 PM
2013FSport
2013FSport's Avatar
Received 1,484 Likes on 1,238 Posts
If anyone does this job, use a Snap-on bushing cutter to fold the edge of the tube seal inward and then use a small pry bar but first place a paint stir stick across the edge before prying up the seal you rolled over!
** Very important: when hammering on the seal cutter, back the opposite side of the cover with a firm piece of wood. **
Yodog (07-29-23)
Old 05-02-20, 12:24 AM
NewyDJ
NewyDJ's Avatar
Hey Guys newbie here, are the valve gaskets the same for each side? Gracias Amigos!
Old 12-08-22, 12:11 PM
MNEWGEN
MNEWGEN's Avatar
No they are different part numbers:
Driver's side: 11214-31020
Passenger side: 11213-31040
Spark plug tube gasket/o-rings: 11193-70010
thelexexpress (12-15-23)
Quick Reply: 150k miles valve cover gasket changed
